The client is experiencing an issue where the ACF built header and footer are not appearing on the translated version of their website.
If you're facing a similar issue where your header and footer are not showing on the translated pages, we recommend the following steps:
1. Navigate to your Theme Settings page from the dashboard.
2. Use the language switcher in the top admin bar to switch to the secondary language.
3. Click on the Update button in the Publish tab.
For more detailed instructions, please refer to our documentation on Translating the ACF Options Page custom fields with WPML.
Last updated by Noman 1 year, 11 months ago.
Assisted by: Noman.
December 21, 2023 at 2:08 pm #15111019
morganC-6
We are facing the issue to show the header and footer.
For Example in default languages, the header and footer is appearing:
but on the translated version it is not showing, please help resolve this and guide me on it.
December 21, 2023 at 2:31 pm #15111205
Noman
WPML Supporter since 06/2016
Thank you for contacting WPML Support. I have noticed that the header/footer is coming from the ACF Options page. To display the ACF options page fields into a secondary language you need to follow the below steps:
1. From your dashboard, go to Theme Settings page.
2. Use the language switcher in the top admin bar to switch to a secondary language:
Here is a doc for more details:
https://wpml.org/documentation/related-projects/translate-sites-built-with-acf/translating-the-acf-options-page-custom-fields-with-wpml/
Please let me know if this resolves your issue or if you need further assistance with this issue
Thank you
