Hello, I have installed WPLM and I'm testing it to translate an article. I noticed that the WP Recipe Maker card is not being translated. In the editor, I can see that it is translated, but when I preview it, it is not. If I choose to translate everything automatically, can I select only the most famous articles? Do you offer a trial so I can see how it will look on my blog? I had used GTranslate before, and my blog was translated into English in every detail. Now I'm not sure what to do. Can you help me? Thank you. Solution: https://wpml.org/forums/topic/help-3/#post-13925413 Relevant Documentation: https://wpml.org/plugin/wp-recipe-maker/
Sorry, but I have more questions. I wish it were simpler.
3 questions:
Actually, what I meant was that I want to publish my website in English but keep it hidden. So, based on your response, as long as I keep the "hidden" option checked, it won't be visible to anyone, correct?
I just encountered another issue. An article that is already translated doesn't appear when I send it for revision with ATE. I receive the message shown in the screenshot, and I'm unable to revise it.
I had opted for on-demand translation for my entire site. I translated everything automatically, and since then, I haven't added any new content. The translation is already done, and even if I delete it and add it again, I shouldn't be charged extra. However, I was billed an additional 100 euros. I don't understand. As you can see in this screenshot, it's clearly stated.
Languages: English (English )Portuguese (Brazil) (Português )
Thanks for your reply.
Answering the questions:
That's right, but you still need to enable the English language for you, in case you haven't done it yet (the tutorial is described in the documentation I linked above).
Please try to go to WPML -> Translation Management, resend this job to translation, then check in your WPML -> Translations queue if you're able to open it now.
Regardless, as the original issue is resolved, and due to our support policy of having one issue per ticket (https://wpml.org/purchase/support-policy/), may I kindly ask you to open a new ticket for those new questions, if you're still stuck?
This will also help other users with similar problems find solutions when searching the forum as well as we avoid mixing lots of questions in one ticket.
So indeed, I understood that it would be wise to open a new ticket, but when I tried to do so, I was redirected to this ticket. I will try again and hopefully, I will have someone to respond to me because, from what I read on the forum, many posts are left unanswered.
Regarding my issue with certain articles that I can't revise with ATE, I remembered that these are articles where I changed the translation of the URL (slug) because it wasn't translated correctly. I used the WordPress editor to do that.
I followed your suggestion and managed to revise them. However, all the corrections I made with the WordPress editor are no longer there. I tried to add a revision again, but the same issue occurs. When I try to send it for review, the old text appears.
In these circumstances, that is an expected scenario, I'm afraid. If you:
- translate a page using ATE
- later, make changes in the translated page using the manual editor (WordPress editor)
- update the translation again with ATE
In this reply: https://wpml.org/forums/topic/help-3/#post-13925413, we have warned you that from now on you'll need to avoid the switch between editors, since now we're also going to use the automatic translation (and therefore ATE) for the recipes, while before they were translated only through the manual WP editor.
I hope that this explanation is clear to you and solves the question. Thank you.
After me or someone else has done the translations on ATE, if one day I revise an article manually, I never have to correct it again with ATE so that it doesn't get overwritten?
Or even if I don't send the article back to ate if the "translate everything" option is activated, it will overwrite the translation done on ate?
To avoid this, after translating all, if I disable "translate all" can I work on my articles freely? Sometimes I go to articles and add an idea or two.
Is the translate some option better in this case? I could benefit from translating the WPLM recipe sheet but if I make a correction afterwards manually, it will not be overwritten?
Thank you very much for your patience and help; I have made good progress. thanks again
Hello there,
Regarding the new questions:
That is right. The manual changes will be always overwritten when updating the translation with ATE.
Yes, it is not recommended to use the 'Translate Everything' mode in this scenario.
You can, but you'll still have the same question: if you make manual changes and then update with ATE - those changes will be lost.
No, the only overwrite that will happen is to the manual changes - when updating the translation with ATE (and not the opposite, if you're asking that).
Hello ,
yes it is good and very clear; Thank you very much for being there to help me. Have a nice day. I close this ticket
Manage Cookie Consent
Functional
Always active
Preferences
Statistics
Marketing
