You are trying to synchronize products from an ERP system to your WordPress website and want to add English translations simultaneously to avoid manual translation later.
We recommend using the WordPress REST API in conjunction with WooCommerce Multilingual to automate the process of creating both the original product and its translation. You can find more details on how to implement this here.
Please note, this type of custom integration is outside our standard support scope. If you need further assistance, consider reaching out to a WPML-certified developer here.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should you need further assistance, please do not hesitate to open a new support ticket here.
Last updated by Bruno Kos 4 months, 2 weeks ago.
Assisted by: Bruno Kos.
May 9, 2025 at 3:23 am #17014257
edmondC-2
I am trying to synchronize products from an ERP system to my WordPress website. During this process, I want to add English translations simultaneously to avoid manually adding translations later.
No specific issue or error message mentioned.
How can I add translations simultaneously when synchronizing products from ERP to my WordPress website?
May 9, 2025 at 6:47 am #17014678
Bruno Kos
To add translations while syncing products from your ERP, you can use the WordPress REST API together with WooCommerce Multilingual. This allows you to create the original product and its translation in one automated process. More details are available here:
https://wpml.org/documentation/related-projects/woocommerce-multilingual/using-wordpress-rest-api-woocommerce-multilingual/#create-products
Please note, this kind of custom integration is outside our support scope, but you can reach out to a WPML-certified developer for help:
https://wpml.org/contractors/
