Supporter timezone: Africa/Cairo (GMT+02:00)
Last updated by Osama Mersal 1 year, 10 months ago.
Assisted by: Osama Mersal.
June 25, 2024 at 8:10 am #15817899
abdelmohaymena
نبذة عن المشكلة:
I am having some problems with WPML on my site which is currently under development (الموقع قيد التطوير).
أعراض:
Various elements are not appearing or functioning correctly on the Arabic version of my site.
أسئلة:
1-in home page (hidden link) first section the circles not appear (hidden link) and you can click to the circle and drag. see English page it is work.
2-in this page (hidden link) title divider error (hidden link)
3- how translate back to top (hidden link)
4- in this page (hidden link) WGL Parallax not appear (hidden link)
5- in this page (hidden link) WGL text path not appear (hidden link) like EN page
June 25, 2024 at 9:56 am #15818939
Osama Mersal
1) Let us focus on the first issue, the home page issue. This section seems to be done using custom coding or a page builder.
You would need a different template or code for Arabic in order to make it work correctly. Arabic is an RTL language, so you would need to change the values of the attributes accordingly.
Osama
June 27, 2024 at 2:22 pm #15844730
abdelmohaymena
Debug information
June 27, 2024 at 2:27 pm #15844784
Osama Mersal
1) Thanks for the debug info. It's unrelated to the issue, but according to your Debug.info, the WP memory limit needs to be increased. PHP memory is fine, but WordPress uses 40Mb as default. The minimum requirements for WPML are 128 MB. (Kindly check this page https://wpml.org/home/minimum-requirements/)
You can increase it by adding the following code in your wp-config.php file right before the /* That's all, stop editing! Happy publishing. */ line:
/* Memory Limit */
define( 'WP_MAX_MEMORY_LIMIT', '256M');
2) I noticed that the first two issues are fixed. Please let me know if you need further assistance with them.
3) Please try the following steps to translate the untranslated string:
1- Go to WPML-> Theme and plugins localization, select your theme/plugin, and scan
2- Go to WPML-> String Translation
3- Scroll down and click on the "Translate texts in admin screens »" link
4- Search for the needed strings
5- Select the strings
6- Click on the "Add to String Translation" button
7- Then click on the "« Return to String Translation" link
8- Translate the strings, clear the cache, and check the front end
Kindly check our guide to know more about translating texts in the admin texts screen. (https://wpml.org/documentation/getting-started-guide/string-translation/finding-strings-that-dont-appear-on-the-string-translation-page/)
Osama
The topic ‘[Closed] I am having some problems with wpml’ is closed to new replies.
