Tell us what you are trying to do? - I am using the ClassiadsPro theme on my website which support WPML plugin and theme is using the Directory press plugin(https://wordpress.org/plugins/directorypress/) for posting of classified ads on website . Please help me to translate the front end ads posted by users on website.
Is there any documentation that you are following? - No there is no documentation
Is there a similar example that we can see? - No
What is the link to your site? - Please find the website detail below :
[removed]
Please check the above detail and help us to translate the ads posted by the front end users.Please also find the login detail for front end user
I've checked your Website and I think I know what you needed there. Please enable translation by navigating to WPML > Settings > Post Types Translation > Select Translatable
only show translated items for the "Listings (dp_listing)" as shown in the attached screenshot.
Once you've done that, you'll be able to translate the listings without issues. Could you give it a try?
