Last updated by Alejandro 1 year, 9 months ago.
August 17, 2023 at 10:03 am #14244633
cronutsd
I have installed the mega menu on my website and parts of the translations do not translate well and the footer does not translate well either.
August 17, 2023 at 12:30 pm #14245841
cronutsd
August 18, 2023 at 12:30 pm #14252477
Alejandro
WPML Supporter since 02/2018
Hello!
I'll try to help you get started while a supporter takes your case.
A mega menu is typically created under appearance > Menus, and require a manual translation as opposed to the automatic sync of the menu elements.
I'd suggest that you try to translate the menu manually and see if things improve. you can follow this guide to do so: https://wpml.org/documentation/getting-started-guide/translating-menus/#option-2-translating-menus-manually
If that's not the case and the mega menu is created in another way, then please give us more details about how it works so we can better understand how to continue.
The topic ‘[Closed] I have a problem with the translation of the footer and the heather.’ is closed to new replies.
