The client was experiencing issues with translating a WooCommerce composite product into Italian using WPML. The translation process was not functioning correctly, sometimes affecting the default English product as well. Specifically, when scenarios were added to composite products, the component dropdown options were not displaying correctly in the Italian version, though they worked fine in English.
We advised the client to ensure that all plugins were up to date and to use the Advanced Translation Editor (ATE) for translating products. It was important to translate using ATE rather than the WordPress Editor to avoid issues with saving changes and to ensure the translation process was handled correctly by WPML. We also suggested translating the products step-by-step using ATE and checking if the issue persisted. If problems continued, we recommended deactivating the WPML plugins temporarily to verify if the issue was indeed related to WPML or if it was an issue with the WooCommerce Composite Products plugin.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket here.
Last updated by Carlos Rojas 8 months, 2 weeks ago.
Assisted by: Carlos Rojas.
January 7, 2025 at 12:07 pm #16569405
marioG-45
Hello Osama,
Thanks for the update.
As I checked the other product and I'm getting issue while saving Italian product.
When I'm saving the scenarios and coming back then those selected scenarios was don't saved. I don't know why. You can check the video which I shared video link is below.
Video link - hidden link
Product link - hidden link
You can directly modify that product as well.
So could you please check it and let me know.
January 7, 2025 at 12:55 pm #16569530
Osama Mersal
WPML Supporter since 02/2020
Please edit the components and select the Italian product. Then, please edit the scenarios and check if they will work correctly.
Osama
January 7, 2025 at 1:16 pm #16569604
marioG-45
Hello osama,
Yes but first I have created the English language product and then I have translate that product. So every time I need to selected that component for Italian language. Why it can't taking and selecting automatically?
Suppose I have thousand of products in woocommerce. So it will difficult to go and select Italian product every time. Could you please check on that and let me know.
Also I'm checking on other products. I will get back to you soon.
January 7, 2025 at 1:36 pm #16569745
Osama Mersal
Could you please install the "WooCommerce Composite Products" to the sandbox site to replicate the issue?
Osama
January 8, 2025 at 7:04 am #16572164
marioG-45
Hi Osama,
The support team create the fresh WordPress site with Woocommerce and WPML plugin only. In the sandbox site product setup is not there as our site. Because support team is created that and also they don't have the woocommerce composite product plugin because we purchased it from woocommerce. Is not possible to install it without buying another license. Can WPML buy it?
Staging site :- We had created the copy of our live site and give it to the support team.
Staging site link :- hidden link
Accessing it you can see also the Composite product and get all the interactions and (mis)behaviour of WPML plugin.
If you are not to buy the Composite plugin to add it into SandBox, the quickest and easiest way it to access our Stafging site and fix it from it.
Waiting for your kind feedback.
Many thanks,
Kind regards,
Mario Garsi
January 8, 2025 at 12:14 pm #16573184
marioG-45
Dear Osama.
Waiting for your kind and prompt feedback.
Many thanks,
kind regards,
Mario Garsi
January 8, 2025 at 5:34 pm #16574803
marioG-45
Kind Reminder nr.2
January 8, 2025 at 6:29 pm #16574957
Osama Mersal
Hi Mario,
I'll check with our compatibility team if we have a key for the "WooCommerce Composite Products" plugin. I'll update you as soon as they reply.
Kindly note that I'll be on vacation for a couple of days, so my reply might be delayed.
Thanks for your understanding
Osama
January 9, 2025 at 6:52 am #16576092
marioG-45
Hi Osama,
It's about 2 weeks we have ping-pong emails without even seen the problem, while accessing our staging site you would be able to see the bug immediately.
Please note we can't launch the website because WPML bug and we are losing money.
Please speed up in tackling the issue and, if you are off, involve your deputy to continue working on it.
many thanks,
Kind regards,
Mario Garsi
January 9, 2025 at 1:16 pm #16577956
Carlos Rojas
WPML Supporter since 03/2017
Hello Mario,
My name is Carlos and I will continue working on this ticket because my colleague Osama is on vacation.
I'm reading all the messages and watching the videos to fully understand how to reproduce the issue. In the meantime, could you update all outdated plugins that appear outdated in the staging site: hidden link and double-check if the issue disappeared?
Carlos
January 9, 2025 at 3:17 pm #16578648
marioG-45
Dear Carlos,
thanks for coming back to us.
All the plugins just updated (you can check into staging)
The issue is always there. In the same way.
Please find the way to fix it as soon as possible.
many thanks,
kind Regards,
Mario Garsi
January 10, 2025 at 9:08 am #16580819
Carlos Rojas
Hello Mario,
Could you tell me why is 'WooCommerce Multilingual & Multicurrency' plugin deactivated?
January 10, 2025 at 11:54 am #16581899
marioG-45
Hello Carlos,
Thanks for the Update.
I can't deactivated it. You activate it and check it. No issue.
January 10, 2025 at 12:00 pm #16581946
Carlos Rojas
Hi Mario,
I don't understand what you mean in our previous message. Could you elaborate a little more?
January 10, 2025 at 12:31 pm #16582037
marioG-45
Hello Carlos,
I can't deactivated 'WooCommerce Multilingual & Multicurrency' plugin. You activate that plugin if needed. And review the issue if its help us to solve it.
