If you're experiencing a blank page when trying to translate a product using the WooCommerce Multilingual & Multicurrency plugin, it might be related to your browser.
We recommend trying the following steps:
1. Check if the issue persists in a different browser. As noted in your case, switching from Firefox to Chrome resolved the issue.
2. If changing browsers does not solve the problem, it could be related to specific settings or addons in your browser. Unfortunately, we have not been able to pinpoint which setting or addon might be causing this issue.
If these steps do not resolve your issue, or if the solution seems outdated or irrelevant to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If you still need assistance, please open a new support ticket at WPML support forum.
Last updated by Bruno Kos 8 months, 3 weeks ago.
Assisted by: Bruno Kos.
October 24, 2024 at 9:02 am #16325018
gutti
I need help with translating products using the WooCommerce Multilingual & Multicurrency plugin. I was trying to translate a specific product by clicking on the + to the right of the page. The issue can be seen at this link: hidden link
<b>Symptoms: </b>
After clicking on the + to translate a product, I encountered a blank page instead of a page with options to write translated text.
<b>Questions: </b>
Why am I seeing a blank page when trying to translate a product?
How can I resolve the issue of the blank page when translating products?
Here is a short video, showing the problem: hidden link
October 24, 2024 at 1:19 pm #16326468
Bruno Kos
Would you be willing to provide me with WordPress credentials so I could investigate the issue directly?
And also send me 1-2 URL of the products where blank screen occurs (I see Gateway 504 error, this is what you are referring to, correct?)
I marked your next reply as private so that you can safely add credentials.
Bruno Kos
October 25, 2024 at 6:06 am #16329080
Bruno Kos
Can you tell me which browser are you using and which OS?
Can you try another one perhaps? Because this is how it works for me:
October 25, 2024 at 10:23 am #16330117
gutti
I use macOS Mojave, quite old. And Firefox.
I tried Crome now – and it works! So my issue is resolved, I think.
October 25, 2024 at 10:59 am #16330266
Bruno Kos
I see, we had such case recently, however we tried reproducing it in several devices but weren't able to:
https://wpml.org/forums/topic/no-editing-possible-in-wp-translation-editor/
So it is probably some specific setting in Firefox, maybe even some addon, but we weren't able to figure out which one, neither the client.
Thankfully another browser works so it can be used as a workaround.
