Supporter timezone: America/Sao_Paulo (GMT-03:00)
Last updated by Mihai Apetrei 1 year, 7 months ago.
Assisted by: Mateus Getulio.
October 17, 2024 at 9:15 am #16299108
leonidasI
I am working on a site under development and trying to use WPML to translate content.
When I'm translating, the translated page is not showing.
Why is the translated page not displaying the correct design after using WPML?
October 17, 2024 at 9:22 am #16299153
Mihai Apetrei
WPML Supporter since 03/2018
Hi there.
This might happen if you have the secondary languages set to "hidden" (https://wpml.org/documentation/getting-started-guide/language-setup/hiding-languages-on-the-front-end/) or if the translations are not in "Published" state yet but instead, they are set to "Draft" or "Under review".
If you do see the translation but the design is different, the reason why this might happen is due to the way the page builder or the theme stores the styling for the content. Some store the styling in a custom field (the custom field usually contains the "style" or "css" or "layout" or "styling" wording) and that custom field might need to first be set to "copy" in order to have the styling being carried over to the translated page.
After doing this, you should first make a small change on the default language, then save the page, then go to the translation of that page and re-save it - and the CSS should be copied over.
Please check more here:
Let us know how that goes.
Kind regards,
Mihai Apetrei
The topic ‘[Closed] I need help with wpml’ is closed to new replies.
