You are trying to translate Gutenberg templates (both archive and single) for your site and encountering a JSON error when attempting to create translations directly in the backend.
We recommend not creating a different template for each language. Instead, use Translation Management to translate the template from your site's default language. Please follow this guide for detailed instructions: Translating sites that use full site editing.
If this solution does not resolve your issue or seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should the problem persist, please do not hesitate to open a new support ticket for further assistance at WPML support forum.
Last updated by Itamar 1 year, 8 months ago.
Assisted by: Itamar.
August 6, 2024 at 1:56 pm #16044278
glenn
I am trying to translate the Gutenberg templates (both archive and single) for a site under development. I am following the documentation at https://wpml.org/documentation/getting-started-guide/translating-content-created-using-gutenberg-editor/.
I cannot create translations. Making a template in the other language in the backend results in a JSON error.
How can I translate Gutenberg templates (archive and single) without encountering a JSON error?
August 6, 2024 at 7:21 pm #16045289
Itamar
WPML Supporter since 02/2016
Languages: Hebrew (עברית )
You should not create a different template for each language but rather use Translation Management to translate the template from your site's default language. Please follow this guide.
https://wpml.org/documentation/getting-started-guide/translating-content-created-using-gutenberg-editor/translating-sites-that-use-full-site-editing/
Please let me know if you have any further questions.
Itamar.
August 7, 2024 at 12:28 pm #16047912
glenn
HI Itamar,
thank you for the reply. I have figured out how to create them. I do have to say that the guide is not very clear. It is quite confusing to follow.
Kind regards,
Glenn Windhouwer
