 MCC Málaga Gestión Hotelera
Thanks alot Carlos, the file is imported and I have now full access to all my Glosarios.
Meanwhile there is no change on the new page created manually, meaning for now all content sticks on in each language. I am going to give it untill Monday before starting redoing all the pages.
Bien Finde y un saludo
Good evening Carlos, I am having a slight problem with my homepage. During the weekend the automatic translated homepage has been erased on almost all languages and I am not able to get the layouts back. So far I have tried to change some text and re translate it and I have also tried to use to option of overwriting translations and nothing works I cannot get the languages to stick.
Hi again, so I just erased my homepage with automatic translations because it was erasing all layouts. I then published the manually translated homepage I had done the other day and which had not changed anything during the lasts days. After publishing this all the content disappeared again showing Spanish content on all homepages. I then press to manually edit the page and in the builder it shows the content in the correct language. So I have my builder showing me the correct content but the users are shown differently.
After this I have no more to give Carlos, I cannot translate automatic nor can I translate manually. The program does exactly what it feels like with no regards of orders.
Meanwhile after all this work I have put into it my visitors are down 23% from same period last year after 7 years beating records every year.
And also to comment is the spending I have made in the last month on automatic translation (see screenshot) because I am paying for a service that is not working.
All of this of course has nothing to do with the service you are providing as supporter but I hope you can send my complaints further up 🙂
But end of story I cannot get this to work so tell me if it is the moment to change translations service, because I am losing the earnings of the summer campaigns ????
Regards
Carlos, I have just finished creating two new urls with manually translation, the homepage and this url: hidden link
Both of them have now the correct content so please visit them when you can and see if everything sticks on each language or not.
It seems like there is something complicating the creation of new url when I do the manully translating, meaning that I create the url in a new language and then put in the content and save seeing the correct content but then I visit the url and it is not created so it would show the Spanish content. I then have to erase this corrupt page and then creating it again it does seems to save the correct layout. All this we will see in the morning I am just crossing my fingers.
What I can't understand is why I can have 3-5 different languages where this would happened on each url created and it is not the same languages having problems each time. There must be something not working right for all this to happen.
Hi Carlos, sorry for my absence but it is really difficult to work with kids on vacation at home. I appreciate the gesture from the company with the credits :-). About the video call, since I am not able to do anything within your working hours because I have people here with me, I would like to know if we could propone that until Thursday ???
Meanwhile my layouts on the 2 url created have stuck with no changes being applied so I will tonight start making the rest of the content manually.
Seems like if I repeat the steps enough times when the page get corrupted, erasing and republishing, in the end everything sticks. It just put alot more effort in everything.
Confirm me about Thursday if it suits you.
Regards
Hi Carlos, I was not going to sit down until this evening but I have just got a call from our premises that the content has disappeared again. On this url: hidden link as I have told you was created with all translations manually and for 3 days nothing happened with the content but today I have lost almost all of the translations. Nearly all of them now shows the Spanish version. So the original content is lost or erased.
And it does not make sense that the program changes something that is manually build where no translation is done.
Regards
It erased following languages: French, Italian, Holandes, Finnish, danish, Norwegian, Swedish, polish and Portuguese. So only 2 languages stayed like it should.
And from my understanding if I was doing something wrong should the effect not be for all ??? Here I am doing it like it should be done because as you can see I have content and translations working perfectly in some languages but my layouts get erased for no reason
Hi Carlos, I have recorded some videos which I hope can clarify a bit more the situation. Its my first videos so bear over with me. And should they leave you with more doubts let me know.
Regards
Carlos, he encontrado otro cosa muy raro en mis 404, te mando otro video:
También lo mando a quien instalo el código para los proyectos por ser caso que lo suyo tiene algo que ver pero creo firmemente que debe ser algo de WPML
 Carlos Rojas
WPML Supporter since 03/2017
Languages:
English (English )
Spanish (Español )
Timezone:
Europe/Madrid (GMT+02:00)
Buenas tardes!
Por favor comparte las credenciales de acceso al sitio en producción en tu próximo mensaje que he establecido como privado para comprobar si el problema volvió a aparecer.
 Carlos Rojas
Languages:
English (English )
Spanish (Español )
Timezone:
Thanks for sharing the credentials.
I just visited the site, and the URLs are still showing the correct language. I will visit the site later today to check again.
Thanks alot Carlos, meanwhile I have resolved with the programmer the problems around the 404´s. It was a mistake in the coding of the category "CHICAS", there was a conflict been made. He also did a lot of clean up in the database so I hope maybe the problems being generated are getting resolved. I will also keep an eye out during the nexts hours to see if there is any difference in layouts.
Have a nice afternoon
 Carlos Rojas
Languages:
English (English )
Spanish (Español )
Timezone:
That's excellent news!
Good mornining Carlos, these pictures are from yesterday evening but I did not change the layouts again this time so you can see for yourself. I have lost 5 languages and there are still lost this morning.
Regards
 Carlos Rojas
Languages:
English (English )
Spanish (Español )
Timezone:
Good morning!
I just double-checked the test page you created (hidden link) and everything is working correctly.
Let's use this test page as a reference, and let's wait until the issue appears again.
