The client is attempting to remove and reinstall WPML on their sites as it is not functioning correctly. They lack the Duplicator plugin, which is typically recommended for backing up the site before such operations, and they inquired about using an alternative backup solution.
We advised the client to first clarify the specific issues they are encountering with WPML. For the removal and reinstallation process, we recommended following the steps outlined in our guide on resetting WPML, which can be found here: WPML Reset Guide.
Regarding the use of an alternative backup solution, the client can use any reliable backup tool they have, such as MalCare, to ensure their data is safely stored before proceeding with the WPML reset.
If the provided solution does not resolve the issue or seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If further assistance is needed, please open a new support ticket at WPML Support Forum.
Last updated by Carlos Rojas 2 months, 1 week ago.
Assisted by: Carlos Rojas.
May 20, 2025 at 3:25 pm #17053186
thorJ-2
I am trying to remove WPML and reinstall it with your help. I have tried multiple times without success. I have it installed on qmibutikk.no, veteranbilen.com, and nettbutikk.qmi.no, and it does not work properly on any of them. I have been advised to take a copy with Duplicator and send it to you, but I do not have Duplicator. I have backup programs from other companies like MalCare.
WPML does not work properly on any of the sites: qmibutikk.no, veteranbilen.com, and nettbutikk.qmi.no.
Is it possible to remove WPML and reinstall it with your help?
Can I use a backup program other than Duplicator to send you a copy?
May 21, 2025 at 1:24 pm #17057722
Carlos Rojas
WPML Supporter since 03/2017
Thank you for contacting us
1.- Yes, I will be more than happy to help you rest WPML. But before doing so, I will need you to describe why WPML is not working correctly.
2.- Also, please follow the steps described in this guide and let me know if were able to successfully reset WPML: https://wpml.org/documentation/getting-started-guide/language-setup/deleting-languages-and-plugin-data-by-doing-a-wpml-reset-on-your-site/
Carlos
