Last updated by Prosenjit Barman 1 year, 8 months ago.
June 3, 2023 at 11:24 pm #13765161
matiasM-3
Hi! Love your plugin.
I'm trying to switch the site's default language from Español to French, I've done all the steps recommended by your support but nothing happens. Could you please help me ASAP?
June 6, 2023 at 4:16 am #13774989
Prosenjit Barman
Hello There,
Thanks for contacting WPML Support. Sorry for the delay in responding as we are experiencing a high volume of tickets than usual.
I understood that you're having some difficulties while changing the site's default language. The primary steps to change the default language are mentioned below.
- Go to "WPML > Language > Site Languages"
- Add the Language first, that you want to make the site's default language by clicking on the "Add/Remove Language" button.
- After that, click on the "Change Default Language" button and select the language that you want to make the default language.
- Flush the permalink structure by Saving the permalinks from the Settings > Permalinks page.
If you're having issues even after following the steps, I kindly request you to share some screenshots or a video regarding the issue so that I can get a better understanding of the issue and help you to find a solution as soon as possible.
Best Regards,
Prosenjit
June 6, 2023 at 1:29 pm #13779217
matiasM-3
Thank you Prosenjit.
I was not able to solve the issue with those steps, may I send you a temp access to the WordPress Dashboard?
Regards
June 7, 2023 at 12:03 pm #13785361
Prosenjit Barman
Hi There,
It will be better if you could share temporary access (wp-admin and FTP) to your site so that I can investigate the issue closely. If possible, try to share access to a Staging site where the issue is replicated.
Sometimes, we need to take a copy of the site if escalation is required. For this, I may need to temporarily install a plugin called “Duplicator” or "All in One WP Migration" on your site. This will allow me to create a copy of your site and your content. Once the problem is resolved I will delete the local site. Let me know if this is ok with you.
IMPORTANT
-Please make a backup of site files and database before providing us access.
Prosenjit
June 8, 2023 at 7:05 am #13790347
Prosenjit Barman
Hello There,
Hope you're doing well.
Unfortunately, the access you've shared is not working. The Password for the username says incorrect. Would you please check and share the correct credentials in the next response?
I have enabled the private box for you so that you can securely share the access. I will start inspecting the issue and let you know an update as soon as possible.
Best Regards,
Prosenjit
June 8, 2023 at 1:05 pm #13793329
matiasM-3
Sorry for that, please try again now with the same password.
Regards.
June 9, 2023 at 8:06 am #13797455
Prosenjit Barman
Hello There,
Thanks for updating the password. It works.
In order to change the default language of the site, I accessed the "WPML > Languages" section and found that the French language has already been configured as the default language for the site. Please check this screenshot(hidden link) for a better understanding.
As French is already set as the default language of the site, do you still need assistance in this matter? Please let me know the update. I will be happy to assist you.
Best Regards,
Prosenjit
June 9, 2023 at 11:53 am #13799377
matiasM-3
Hi Prosenjit, thank you.
I was aware of that, but the WordPress Dashboard language is still Spanish (not French) and in General Settings the site language seems to be still set in Spanish (please see the attachment).
Regards.
June 12, 2023 at 6:39 am #13806441
Prosenjit Barman
Hello There,
Sorry for the delay in getting back to you due to the weekend.
Thanks for clarifying the issue. I would like to inform you that the language displayed on the WordPress Dashboard is based on the language setting of the user's profile. Upon checking, I noticed that your profile's language is currently set to "Espanol," which is why the dashboard is appearing in the Spanish language. Please check this screenshot(hidden link) for a better understanding.
Please follow the steps below to solve the issue. Kindly note that the names are mentioned in Spanish for a better understanding of the locations where changes need to be made:
- From your WordPress dashboard, Go to the "Usuarios > Perfil" section.
- Scroll down to the "Idioma" section
- From the dropdown beside "Idioma", select "Por defecto de sitio" or "Francais" and save the changes.
After that, the WordPress dashboard will start to appear in the French language.
Let me know the update. I will be happy to assist you if you need further assistance in this matter.
Best Regards,
Prosenjit
