Supporter timezone: Europe/Vienna (GMT+01:00)
Last updated by Bigul 4 months ago.
Assisted by: Bigul.
October 23, 2024 at 6:49 am #16320051
chrysothemisP
We have been using WP Rentals with 3 languages and are facing an issue with the cart on our site hidden link. Support from WP Rentals advised us to contact WPML regarding this issue.
When adding to cart from the English website, we get a 404 error.
October 23, 2024 at 4:40 pm #16322817
Bigul
As of now we only have one known issue with WPRentals. Please check the following links for more details.
https://wpml.org/theme/wprentals/
https://wpml.org/errata/wprentals-invoices-not-visible-in-all-website-languages/
Please increase the *MaxInputVars* of PHP settings to *10000* and check if it helps or not. Refer to the following article for more details and contact your system admin/hosting provider to upgrade this configuration.
Maybe you are facing this issue because of compatibility conflicts. So to make sure if possible, please do the following steps and let us know your feedback.
a) Backup your site first[Mandatory]
b) Switch for a moment the WPRentals parent theme
c) Deactivate all the plugins that are not related to WPML
d) Then check whether the issue exists or not
e) If the issue is gone, activate the plugins as a group of three or four to find which one has an interaction issue
f) Switch back to the original theme of the site
If you have a staging/dev site (a clone copy of the live site), please try the above steps there. It will help us to troubleshoot the bug without affecting the live site.
Bigul
The topic ‘[Closed] Issue with cart’ is closed to new replies.
