You are experiencing issues with WooCommerce orders when using WPML, specifically with an unexpected option to filter orders by language and discrepancies in the total order count when filtering by language.
Firstly, it's important to note that WooCommerce does not typically include a language filtering option in the Orders section. If you're seeing this option, it might be due to a customization or a plugin that modifies the default WooCommerce behavior. We recommend checking your site for any such customizations or additional plugins that might be influencing this behavior. Additionally, for the discrepancies in order counts, ensure that all your translations are correctly configured and that there are no synchronization issues between the languages.
If this solution does not resolve your issue or seems irrelevant due to being outdated or not applicable to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If problems persist, please open a new support ticket at WPML support forum for further assistance.
Last updated by 7 months, 3 weeks ago.
Assisted by: Itamar.
