You are using WPML to translate your products into 26 languages, resulting in 7500 products in your WordPress admin. However, only 750 product URLs are indexed by Google, and the XML sitemap does not contain more than 6500 product links.
If you're experiencing this issue, we recommend you try the following steps:
1. Ensure all products are published.
2. Verify that all plugins and themes are up-to-date.
3. Install WPML SEO if it is not already installed.
4. Re-send the sitemap for indexing in the Google Search Console.
Additionally, please provide the debug information of your site as described here: https://wpml.org/faq/provide-debug-information-faster-support/
Please note that this solution might be irrelevant if it is outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket at WPML support forum.
This topic contains 65 replies, has 2 voices.
Last updated by Carlos Rojas 1 year ago.
Assisted by: Carlos Rojas.
November 18, 2024 at 2:01 pm #16415162
tamer
so need add product from new to can automatically translated with the products tags?
November 18, 2024 at 2:02 pm #16415167
Carlos Rojas
WPML Supporter since 03/2017
You must assign those translation credits to the site. You can see in the screenshot you shared that the site only has 2000 credits assigned.
November 18, 2024 at 2:14 pm #16415215
tamer
ok let this point later
now what about all problems i send later, solved?
November 18, 2024 at 2:31 pm #16415294
tamer
why not answering?
November 18, 2024 at 9:31 pm #16416558
tamer
my question after you solve the problem
when 7000 products link index in google?
you solve problems in 7500 product links are included in the XML sitemap?
how can know the problem it solved, i not expert, so help me to know
send any report!
November 19, 2024 at 10:46 am #16418896
Carlos Rojas
To answer your latest questions:
1.- when 7000 products link index in Google? -> As mentioned in my previous messages, this is up to Google. WPML doesn't index content, search engines do, so you must contact Google's support service and ask them when Google will index the products.
2.- you solve problems in 7500 product links are included in the XML sitemap? -> Yes, all products are in the sitemap, you can see it in this link: hidden link
3.- how can know the problem it solved, i not expert, so help me to know -> From the WPML side, all problems are solved. All the content is correctly setup.
November 19, 2024 at 3:20 pm #16420401
tamer
so best keep ticket open till after 10 days, till google check new xml site map
if you solved problem will be index normally
if not, you will check the problem again
November 19, 2024 at 3:47 pm #16420560
Carlos Rojas
Great!
Let's wait and see the results.
November 21, 2024 at 9:25 am #16428017
tamer
I think there is another problem that prevents archiving each translated product page separately
as "SKU, GTIN, UPC, EAN, or ISBN" it is fixed and does not change with each language as in the attached images one in egnlish and same tour as in germany .
What is your opinion as an expert?
November 21, 2024 at 10:47 am #16428526
Osama Mersal
WPML Supporter since 02/2020
I'm Osama from the WPML support team. To answer your question about the SKU, it doesn't change between languages because if it changes, you won't be able to track and sync the stock between languages.
So, it's the expected behavior for the SKU not to change in the translated languages.
If you want to discuss the issue today, we can arrange a meeting in Arabic. If today is not suitable for you, we can arrange a meeting later, but it will be in English.
Osama
November 21, 2024 at 10:50 am #16428542
tamer
مناسب التواصل باللغة العربية الان وباى وقت
مشكلتي اني خسرت الكثير من الوقت والمال في الترجمة وكانت المحصلة ان اكثر من ٧٠٠٠ رابط لكل اللغات لم يتم ارشفته مع جوجل البحث وتوجد مشكلة مع خريطة الموقع
الدعم قال انه تم حلها
ما هو رد بحكم خبرتك
November 21, 2024 at 10:53 am #16428550
tamer
هل انتظر تحديث جوجل لخريطة ملفات الموقع حتى يشاهد اللينكات من جديد ويبدا في ارشفتها
اريد حلول لاني فعلا في مازق وهذا عملي الخاص بالسياحة في مصر - مدينة الغردقة
منتظر ردك
هل تريد لوحة تحكم لدخول الى جوجل ويب ماستر وادمن الورد بريس
يمكن اعطاءك كافة الصلاحيات
منتظر ردك اسامه
November 21, 2024 at 10:59 am #16428556
Osama Mersal
مرحباً،
لقد قمت بارسال رابط الاجتماع على الايميل الخاص بك المسجل هنا.
تحياتي،
اسامه
November 21, 2024 at 11:43 am #16428741
Osama Mersal
1) WPML can't fix the indexing issue, so you need to contact the Google support team or wait for the Google engine to re-index your site.
2) Here is a guide to translate the tags automatically.
Please share the access details with Carlos. He will test it for you and confirm that the steps will fix the tags issue.
Osama
November 21, 2024 at 12:14 pm #16428850
tamer
I hope make test and confirm me about products tags
