The client is experiencing issues with strings not translating unless the 'AUTO REGISTER STRINGS FOR TRANSLATION' is enabled. When this option is disabled, the strings do not translate.
The issue stems from the Give Plugin not loading its text domain correctly, which prevents WPML from translating the strings. This problem is due to changes in how text domains are loaded in the latest major WordPress release. We recommend contacting the Give Support Team to inquire if they are aware of this issue and to check if an update is planned to resolve it.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should you need further assistance, please open a new support ticket with us at WPML support forum.
Last updated by 3 months, 2 weeks ago.
