I am having this issue where I have translated a WordPress Pattern created with Kadence info block, but on the pages where I use this pattern, only the title is translated but not the content.
To resolve this, follow please these steps:
1. Go to WPML > Settings > Custom XML Configuration tab.
2. Add the following XML code:
<wpml-config>
  <gutenberg-blocks>
    <gutenberg-block type="kadence/infobox" translate="1">
      <xpath>//*</xpath>
    </gutenberg-block>
  </gutenberg-blocks>
</wpml-config>
3. Save the configuration.
4. Edit the original pattern in the default language.
5. Make a small change to the pattern.
6. Update the translation.
This solution registers the custom blocks, making them available for translation and resolves the issue of content not being translated properly.
Relevant Documentation:
https://wpml.org/documentation/support/language-configuration-files/#gutenberg-blocks
Last updated by Mohamed Sayed 1 year, 10 months ago.
Assisted by: Mohamed Sayed.
August 25, 2023 at 12:50 pm #14291905
Thomas
Dear WPML-Team,
I use WordPress Patterns to display them on 2 different pages.
The Pattern "Leistungen" is fully translated:
But on the pages where I use this pattern only the title is translated:
Is there a bug with Kadence info block?
Thank you in advance,
Thomas
August 27, 2023 at 3:59 pm #14296653
Mohamed Sayed
Hi Thomas,
Please try the following steps:
<wpml-config>
  <gutenberg-blocks>
      <xpath>//*</xpath>
    </gutenberg-block>
  </gutenberg-blocks>
</wpml-config>
3. Save it
5. Update it with a small change
Let me know please if that helps.
Kind regards,
Mohamed
August 27, 2023 at 9:03 pm #14296817
Thomas
Thank you. This worked :). Is it a known bug :)?
August 27, 2023 at 9:42 pm #14296859
Mohamed Sayed
I'm glad to hear that the issue is resolved.
It's not a known bug, in some cases you need to register the custom blocks to make it available for translation. This can be done by using a custom XML configuration that tells WPML which parts should be translated.
Please check this guide for more details: https://wpml.org/documentation/support/language-configuration-files/#gutenberg-blocks
