[Resolved] Place order button not showing on translate language
Problem: The client was unable to see the 'Place Order' button on the WooCommerce checkout page when viewing the site in the Arabic language. A PHP fatal error related to an unknown format specifier was identified in the debug log. Solution: We resolved the issue by following the steps outlined in our documentation on PHP 8 PHP Fatal error: Uncaught ValueError: Unknown format specifier in. The specific string causing the issue was located in the file
on line 44. We re-translated the string in WPML > String Translation, ensuring that the placeholder tags "%1$s" and "%2$s" were kept the same in the translation.
If you're experiencing a similar issue, we recommend you try the same solution. However, please note that this solution might be irrelevant if it's outdated or not applicable to your case. If the problem persists, we highly recommend checking related known issues on WPML Known Issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should you need further assistance, please do not hesitate to open a new support ticket in the WPML support forum.
"Since your browser does not support JavaScript, or it is disabled, please ensure you click the %1$sUpdate Totals%2$s button before placing your order. You may be charged more than the amount stated above if you fail to do so."
in WPML > String Translation. You should keep the same placeholder tag "%1$s" and "%2$s" in the translation string.
- Go to WPML > String Translation > Search for the keyword "Since your browser does not support JavaScript".
- Re-translate the string and keep the placeholder in the translation string. For example:
نظرًا لأن متصفحك لا يدعم JavaScript، أو أنه معطل، يرجى التأكد من النقر فوق الزر %1$s تحديث الإجماليات %2$s قبل تقديم طلبك. قد يتم تحصيل رسوم منك أكثر من المبلغ المذكور أعلاه إذا فشلت في القيام بذلك .
