This topic contains 18 replies, has 2 voices.
Last updated by tomaszK-48 1 year, 10 months ago.
Assisted by: Osama Mersal.
March 18, 2023 at 8:56 pm #13275869 | |
tomaszK-48 |
I am trying to: Link to a page where the issue can be seen: example: I expected to see: |
March 19, 2023 at 8:52 am #13277371 | |
Osama Mersal Supporter
Languages: English (English ) Arabic (العربية ) Timezone: Africa/Cairo (GMT+02:00) |
Hi, Thanks for contacting WPML forums support. I'll be glad to help you today. I checked the mentioned product in the front end, and both languages seem to have the same variations. Could you please let me know how to reproduce the issue? If the issue happens only in the backend, please provide a screen recording video while reproducing the issue. Thanks for your cooperation Best regards, |
March 19, 2023 at 11:14 am #13277809 | |
tomaszK-48 |
Hi Osama, thank you for (fast) answer, no, it is not the same: please look at first option (overflade) on dk and there is 3 options, |
March 19, 2023 at 11:17 am #13277811 | |
Hi, Thanks for your update. Could you please try the following steps? 1- Edit the product in the default language Kindly let me know the result of the above steps. Best regards, |
March 19, 2023 at 11:31 am #13277839 | |
tomaszK-48 |
Done, but nothing change 🙁 |
March 19, 2023 at 11:35 am #13277883 | |
Hi, Please try the following steps after taking a database backup. 1- Go to WPML-> Support-> Troubleshooting ❌ Please backup your database before performing the above steps ❌ Best regards, |
March 19, 2023 at 12:36 pm #13278057 | |
tomaszK-48 |
done, |
March 19, 2023 at 12:38 pm #13278059 | |
Hi, I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP) Your next answer will be private, which means only you and I can access it. ❌ Please backup your database and website ❌ ✙ I would need your permission to de-activate and re-activate the Plugins and the Theme and change configurations on the site. This is also a reason the backup is critical. ✙ I also need your permission to take a local copy of your site to debug the issue without affecting your live site. Best regards, |
March 19, 2023 at 2:25 pm #13278445 | |
Hi, Thanks for the access details. The "Krom" variations were not copied to the translated product, so I edited all "Krom" variations to replace "Krom" with "Nikkle" and updated the product in the default language. After that, I reverted them to "Krom", which fixed the issue, and the variations were saved correctly. Please check the translated product and let me know if it works correctly. (hidden link) Best regards, |
March 19, 2023 at 4:13 pm #13278821 | |
tomaszK-48 |
Thanks, after a quick check it seems to work, is there any mechanism to automate this operation? |
March 19, 2023 at 4:20 pm #13278849 | |
Hi, Thanks for your update. Changing the variation and updating the product forces the database to resave the product, which helps WPML to copy the variation to the translated language. I don't think there is an automatic approach to this workaround, but you don't need it unless you face this issue with specific variations. I hope this helps you. If you need further info, please let me know. Best regards, |
March 19, 2023 at 4:25 pm #13278875 | |
tomaszK-48 |
it's brighter however, the case applies to all variants (not just one specific one) in the entire store, slightly counting over 1000, Thanks, |
March 19, 2023 at 4:34 pm #13278899 | |
Hi, If the issue happens to all your variations, please try WooCommerce-> WooCommerce Multilingual-> Status-> troubleshooting. (Kindly check the attached screenshot) Best regards, |
March 19, 2023 at 6:57 pm #13279087 | |
tomaszK-48 |
thanks, do i have to set something to activate this tab? |
March 19, 2023 at 7:00 pm #13279089 | |
Hi, Please go to WooCommerce-> WooCommerce Multilingual-> Status tab, and click on troubleshooting. Best regards, |
