Last updated by Subash Chandra Poudel 1 year, 8 months ago.
October 27, 2023 at 2:02 pm
botiss-biomaterialsG
HI, we have a problem with avada layouts. we have 4 languages . But I do not understand, should we create new layouts for each language , or just one layout
October 27, 2023 at 2:52 pm
October 30, 2023 at 3:31 pm #14693233
To test the issue further, I tried to replicate the issue on test sites. But as explained in the document linked next I was able to select all Categories and their translation for layout conditions when I selected "All Languages" from the language switcher in the top bar in the test site.
https://wpml.org/documentation/theme-compatibility/using-wpml-with-the-avada-theme/#applying-conditions-to-avada-layout-sections
So the issue that all categories translations are not available to select when "All Languages" is selected seems to be specific to your site and not a general issue with WPML and/or Avada.
I can see on your site when you create different layouts for different languages by switching the language switcher at the top bar in wp-admin -> Avada -> Layout and assigning corresponding categories for the conditions it is working fine, so in the meantime, you can create different layouts for different languages and make it work.
Now, to troubleshoot the issue can you please:
- Back up the site completely to prevent any issues.
- Deactivate all plugins except WPML, WooCommerce, and any other critical plugins ( if any ).
- Test if the issue gets resolved now. If yes, activate plugins one at a time to see which one starts the issue.
let me know how the test goes.
Subash
November 2, 2023 at 9:33 am #14714333
Thanks for your supporting.
I will copy it as a new website in my localhost and be testing to define what is the problem.
However, I got a problem with the Layout on ES. If I create a new section as and type name for this, the section will be moved in English without reason or error.
If you have time or would like to help us, you can catch it. I think you have more experience than me.
New threads created by Subash Chandra Poudel and linked to this one are listed below:
https://wpml.org/forums/topic/split-problem-with-avada-layouts/
November 3, 2023 at 3:02 pm #14726759
Sure, please let me know how it goes once you test the issue on a copy site.
Regarding the layout issue please note, that we try to handle only one issue per ticket to better keep track of issues and stay on the same page. So I have split the issue as a new ticket. I will followup on the new ticket regarding the layout issue.
The topic ‘[Closed] problem with avada layouts’ is closed to new replies.
