Hi, we are trying to translate our website and we use theme with "Elementor" builder.
The method we use to translate it is by exporting .XLIFF files that we forward to a translation team.
The problem we encounter is that, on export the page content is built with an elementor, much of it is not available in the exported files and thus remains untranslated.
Some of it is available... like the "Text editor" elements, but not the ones for the "Titles", "Buttons", "Testimonials", etc.
Could you please help or advise what might be the problem to export all content from all page elements?
This is the site we are trying to translate from English to Bulgarian: hidden link
And this is the Bulgarian version of the homepage, which, as you might expect, is mostly not translated hidden link
Languages: English (English )Spanish (Español )German (Deutsch )
Could you please let us know which are the Elementor Widgets that are not getting translated and which component of your site is responsible for those widgets?
WPML by default supports all widgets that are shipped with Elementor and Elementor Pro.
Every Custom Elementor Widget must have an XML configuration so that it can be translated using the WPML Translation Editor.
It is the theme author's job to create such a configuration in a wpml-config.xml file in the root directory of the theme or plugin.
If the author does not provide such a config, you can alternatively create one yourself. This config can be stored under WPML > Settings > Custom XML Configuration.
We can further offer a WPML test site on which we can recreate the issue and I assist you with a basic configuration for a couple of widgets, but if there are many affected widgets it would be better to reach the author of those widgets.
This is the elementor widgets that content missing after exporting to XLIFF
- "Heading"
- "Button"
- "Features Single"
- "Call To Action"
- "Testimonials"
Do you think we can miss some of the WPML configuration option responsible for that kind of exporting?
Thank you for contacting WPML support, I’m happy to help you with this issue.
Yes. I see those Elementor widgets on the homepage are created by the plugin "Aheto" on your site. The widget's content might not be registered for translation so you won't see it in the XLIFF file.
Hello
Based on the instructions above, I was able to register 3 of the plugins responsible for most of the untranslated texts with .
- "Heading"
- "Features Single"
- "Testimonials"
While i tested each 1 individually when registering them they worked correctly in the test page.
On export, the previously missing texts, was exported successfully.
However, on import, the texts on the pages were not translated.
After several tests, I noticed that when I turned on the translation editor to see if the fields were translated, sometimes they were visualized and sometimes they were not, and only the old fields remained without the ones with the texts from the newly registered plugins.
Now they are currently missing as well.
I put the code I added in "Custom XML Configuration" of WPML:
URL TO FILE WIT THE CODE: hidden link
The topic ‘[Closed] Problem with Elementor translating’ is closed to new replies.
Manage Cookie Consent
Functional
Always active
Preferences
Statistics
Marketing
