This topic contains 33 replies, has 2 voices.
Last updated by Marsel Nikolli 1 year, 10 months ago.
Assisted by: Marsel Nikolli.
May 8, 2024 at 4:35 pm #15607293
miroslavN
I spent over 10 hours investigating this problem and found that it is related to Elementor from version 3.19.4 onwards. This version introduced the beta Flexbox Container, which is enabled by default. After installing WPML's String Translator, I encountered some issues with Elementor, so I tried toggling a few beta features on and off.
Here's what I've found to be the correct configuration for these beta features in the latest versions of Elementor/Elementor Pro.
I'm not sure if WPML's String Translator is working correctly, and I don't have the time to explore its settings or troubleshoot further. However, I did notice the following message in Query Monitor: "rtrim(): Passing null to parameter #1 ($string) of type string is deprecated" in the "sitepress-multilingual-cms" plugin on PHP 8.1. (I've encountered even more issues with PHP 8.2, so I'm sticking with PHP 8.1 for now.)
If you can confirm that this issue is acceptable or provide any guidance, I'll continue learning about WPML and proceed with translating my site. Thanks in advance for your assistance.
May 9, 2024 at 7:31 am #15608965
Marsel Nikolli
Thank you for the detailed information about the issue, I'll pass it to the 2nd tier team.
Meanwhile can you please check the configuration on the sandbox (as in there it should be working correctly): hidden link
This page for example is working now and it wasn't before: hidden link
Looking forward to your reply,
Marsel
May 16, 2024 at 4:53 am #15632800
miroslavN
It looks that works fine 🙂
May 16, 2024 at 7:55 am #15633344
Marsel Nikolli
Thank you for the update.
Let me know if you have any questions or need further help.
Kind regards,
Marsel
