The client is using WPML with WooCommerce and the WooCommerce Side Cart Premium plugin. They have set a threshold for adding free products in the main language (PL) and want to set different thresholds for other languages (EN, DE, CZ) with different currencies.
We recommended checking if the threshold setting is stored as a custom field or within the plugin options. If it's a custom field, the client can set it to 'translate' using the guide on Translating Custom Fields. If it's a global plugin option, the client should register it for translation following the instructions on Finding Strings that Don't Appear on the String Translation Page.
The client successfully found the threshold value under WPML → String Translation → Translate texts in admin screens, registered it for translation, and set different values for each language.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If further assistance is needed, please open a new support ticket.
Last updated by 2 months, 2 weeks ago.
Assisted by: Bruno Kos.
