Supporter timezone: Europe/Kyiv (GMT+02:00)
This topic contains 58 replies, has 2 voices.
Last updated by Andrey 1 year, 6 months ago.
Assisted by: Andrey.
June 18, 2024 at 5:26 pm
deliaV-2
I am trying to translate my website from Romanian to English. I have three taxonomies: Atractii, Tip Cazare, and Locatii. All translations are done in the backend, and I managed to show translations on the frontend after much effort. I am using the BA Booking plugin.
Dynamic content is not showing even though it is populated. The main category affected is Booking categories.
Can I send credentials in order to fix this?
June 18, 2024 at 8:34 pm #15750886
Andrey
WPML Supporter since 06/2013
How are you displaying your content? Are you using a shortcode, a widget, or something else?
Could you please provide a step-by-step process with screenshots? This will help me better understand and address the issue.
June 19, 2024 at 8:10 am #15753776
deliaV-2
I am using Elementor to display taxonomies and booking categories. In the backend are populated, but something is set up wrong in wpml and are not displaying. Can you have a look as it is super urgent..
June 19, 2024 at 8:15 am #15753835
deliaV-2
Here are populated categories, and on frontend are showing in dropdown but still not showing. Other taxonomies are ok, like destinations
June 19, 2024 at 8:28 am #15753993
deliaV-2
Also I disabled language switcher from menu, but you can acces via /en
June 19, 2024 at 1:37 pm #15756061
Andrey
Thank you for the explanation. Now, I can see the problem.
Could you update all Elementor plugins and see if the problem remains?
June 20, 2024 at 10:43 am #15762895
deliaV-2
I have updated and now I have problems with the theme as well. and issue is still there
June 20, 2024 at 10:59 am #15763056
deliaV-2
I will do a staging website and try there, please dont close the ticket
June 20, 2024 at 11:05 am #15763140
Andrey
Thanks for the update. I suggest testing this also on a fresh installation (with a fresh theme and Elementor).
June 20, 2024 at 11:17 am #15763225
deliaV-2
the site should work with this version of elementor, please check again until i have the staging. for sure is something settings related and it's urgent
June 20, 2024 at 11:24 am #15763274
Andrey
I still see that the Elementor plugin, including Elementor Pro, has not been updated. Please let me know when all the latest plugins are installed so we can proceed with further checks.
This may not necessarily resolve your problem, however, in order to troubleshoot the issue best we need to work on the latest code available.
Please make sure that you have update your current theme to the latest version.
Let me know how it goes.
June 20, 2024 at 11:44 am #15763405
deliaV-2
The latest version broked my website (some menu elements and events page - but nothing related to wpml). After I noticed this, I quicky checked the module to see if it's fixed but it wasn't. So I used a backup and put the site as it was before
June 20, 2024 at 11:45 am #15763421
deliaV-2
The module that displays accomodations in english
June 20, 2024 at 7:39 pm #15766681
Andrey
You should update your current theme to version 2.4.8 to fix bugs with the latest Elementor plugins. Updating everything will help us address the issue further.
#Changelog
### Version 2.4.8 date 17/06/2024
- Fix the widgets bug in Elementor 3.22.0
### Version 2.3.7 date 07-05-2024
- fix: Warning in oneclick
### Version 2.3.6 date 02-04-2024
- Update: Dashboard profile
### Version 2.3.5 date 14-3-2024
- Update font icon
### Version 2.3.4 date 14-12-2023
- Update Compatible Elementor 3.18.0
June 21, 2024 at 9:57 am #15773565
deliaV-2
here is staging version with everything updated. problem still persists and now I cannot see the menu anymore
The topic ‘[Closed] Problem with taxonomy translation’ is closed to new replies.
