We have wordpress multisite instalation where seperate sites have own content and own subdomian domains. Default site have activated plugin and it appears to work fine. Worse situation are in other sites. When I want to setup wpml plugin on them it show me default site domain (https://xxx.ww) not domain which is specify to site (eg https://yyy.xxx.ww ) so i can not activete plugin on separete activation key. I have try reset wpml for that sites but witout success.
What should I do to have separate accounts on each sites if it is posible?
Out of the box, achieving this with WPML is impossible.
You don't need to register WPML on each subsite in your WordPress multisite installation. Registering your main site first allows you to use the same WPML site key for all the subsites in the same multisite setup. When you activate and configure WPML on your subsites, they will be registered automatically.
Relevant Documentation:
https://wpml.org/documentation/support/multisite-support/#registering-wpml-on-multisite
Last updated by Itamar 1 year, 5 months ago.
Assisted by: Itamar.
December 14, 2023 at 8:20 pm #15068719
karolinaK-17
Worse situation are in other sites. When I want to setup wpml plugin on them it show me default site domain (hidden link) not domain which is specify to site (eg hidden link ) so i can not activete plugin on separete activation key. I have try reset wpml for that sites but witout success.
December 18, 2023 at 4:41 pm #15086277
Itamar
WPML Supporter since 02/2016
Activate the OTGS Installer plugin either for your whole network or just your main site.
Please check our relevant guide here.
Itamar.
December 19, 2023 at 6:49 am #15088631
karolinaK-17
Hi, i know I can activate only main site and other rest will be working. But You do not answere my question. We wolnd like to use multiple accounts in ours instalation, each site have seperate accounts. Is it eaven posible? If yes how to do that?
December 19, 2023 at 11:19 am #15091673
Itamar
I'm sorry if I was unclear about this.
If possible, it will be with custom coding, which is out of the scope of our support forum. If you need further help with what you are trying to achieve, I would suggest you consider contacting one of our certified partners from this link:
https://wpml.org/contractors/
Before doing so, please have a look here:
https://wpml.org/documentation/about-wpml-contractors/what-type-of-work-you-can-expect-from-contractors/
With our contractors, you might get the custom assistance you need to get on with your project.
Itamar.
December 19, 2023 at 12:54 pm #15092653
karolinaK-17
Thanks for Yours reply and suggestions.
