You have a multilingual website with 7 languages and want to use automatic translation for certain languages and manual translation for others, specifically for blog posts. However, the auto-translate feature tried to translate already translated posts and corrupted the Blog page.
If you're experiencing this issue, we recommend you configure your WPML settings to selectively use automatic translation. Here's how you can do it:
1. Navigate to WPML -> Settings -> In the first section, set the configuration to automatically translate only the content you select.
2. Go to WPML -> Translation Management, select the blog posts you wish to automatically translate, and send them for automatic translation.
Save the changes after each step.
Please note that this solution might be irrelevant if it's outdated or not applicable to your case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket at WPML support forum for further assistance.
Last updated by 6 months ago.
Assisted by: Carlos Rojas.
