Home›Support›English Support›[Resolved] [Product Category Discount] When the language is switched to Russian on the same product discount does not applied
[Product Category Discount] When the language is switched to the second language on the same product discount does not apply.
1- Go to Product Category Discount
2- Make sure to apply the discount to categories in all languages
Thank you, this was fixed. I found another issue. I use the plugin "Product Category Discount"
to make discounts for the whole product category. So it works when the language is Latvian, but when the language is switched to Russian on the same product discount does not applied.
For example this: hidden link
First of all, sorry for the late reply due to a higher workload. Please log in to this sandbox site and upload the "Product Category Discount" plugin. (hidden link)
After that, please create discount rules to replicate the issue. If the issue is replicable, please let me know how to reproduce it to check it and consult our compatibility team.
The debug info will give me a lot of information about how your site is configured.
I installed the WooCommerce Multilingual plugin, created a post, and translated it. After that, I applied the discount to the categories in all languages.
When visiting the products in all languages, you will see the discount. (Kindly check the attached screenshot)
Kindly check the sandbox and let me know if the issue is replicable.
Thanks for your update. I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
Your next answer will be private, which means only you and I can access it.
Thanks for the access details. I checked your site and found that the discount is not applied to the Russian category. (Kindly check the attached screenshot)
After applying it, the discount worked correctly. Kindly check this product. (hidden link)
I hope this helps you. If you need further info, please let me know.
