The client is facing an issue where translated products on their website do not automatically use the same image as the original product. They want to avoid duplicating the image in the media folder and ensure that the same photo is used across all languages.
We recommend following these steps to ensure that the same image is used across all languages when translating a product:
1. When creating or editing a product in the original language, navigate to the right column to the Language block.
2. At the bottom of this block, select the two checkboxes to duplicate the featured image and the attached media.
3. Save the changes.
4. If necessary, update the product translation and double-check that the translated product now displays the same images as the original.
For more detailed guidance, please refer to the first FAQ at the end of our documentation here: WPML Media Translation FAQ.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your specific case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should you need further assistance, please do not hesitate to open a new support ticket at WPML Support Forum.
Last updated by Carlos Rojas 1 year, 1 month ago.
Assisted by: Carlos Rojas.
March 26, 2025 at 3:56 pm #16864085
rayaA
I am trying to ensure that when a product is translated on my site hidden link, it retains the same image as the original product. I do not want to duplicate the image in the media folder; I want the same photo used across all languages. I have been following the documentation at https://wpml.org/documentation/getting-started-guide/media-translation/ but could not find how to set the image to not translate.
When translating a product, the translation doesn't have an image. If the image is chosen separately for each language, it remains unchanged if updated in one language.
Which setting should I change to ensure the same image is used across all languages?
How can I sync product images across all languages so that changes in one language reflect in others?
March 28, 2025 at 8:10 am #16871426
Carlos Rojas
WPML Supporter since 03/2017
Thank you for contacting us
Your products are using the same image as the one in the default language. You can read the explanation in the first FAQ at the end of the documentation you shared: https://wpml.org/documentation/getting-started-guide/media-translation/#frequently-asked-questions
Please let me know if you need further assistance.
Carlos
March 28, 2025 at 1:13 pm #16873121
rayaA
When I create a new product, set an image for it, and then translate it, the translation DOES NOT has that image. Kindly tell me how can I make it happen so that when translating a product, the translation will have the image automatically without me needing to choose the image for each and every translation.
March 31, 2025 at 9:54 am #16878380
Carlos Rojas
In this case, you need to follow these steps:
- When creating/editing a product in the original language, go to the right column -> Language block -> Select the two checkboxes that appear at the bottom of the box to duplicate the featured image and the attached media -> Save the changes
- Update the product translation if necessary
- Double-check that the translated product now shows the same images as the original one
Looking forward to your feedback.
