This topic contains 17 replies, has 3 voices.
Last updated by Andrey 1 year, 1 month ago.
Assisted by: Andrey.
August 21, 2024 at 5:33 pm #16091713
marcisL-2
Site owner
I have fully translated one of my products from Latvian to English (translation is 100% complete), but when I go to the product's English version, it is empty (there is no text, translation is not applied).
The English version of the product page is empty, and I see WPML error logs with the topic: 'The xliff file could not be read'. Extra data: {"downloadUrl":"hidden link"}
Why is the English version of my product page empty despite the translation being 100% complete?
What does the WPML error log 'The xliff file could not be read' mean?
How can I resolve the issue with the xliff file not being read?
August 21, 2024 at 9:18 pm #16092269
Andrey
WPML Supporter since 06/2013
Can you please update your WooCommerce Multilingual & Multicurrency to 5.3.7?
This may not necessarily resolve your problem; however, we need to work on the newest code available to troubleshoot the issue best.
You can check the latest released versions under "My Account -> Downloads" on this site. Instructions to update can be found here: http://wpml.org/faq/install-wpml/
If you do not see the updates, you might need to click the Check for updates button in the Plugins → Add New Plugin → Commercial tab.
Then, you should slightly modify the original product, save it, and navigate to the WPML translation editor to complete the translation.
If there is still a problem, please upload the screenshots.
Please remember to backup your database before you proceed.
August 22, 2024 at 7:25 am #16092963
marcisL-2
Site owner
WooCommerce Multilingual & Multicurrency was already updated to 5.3.7. I probably copied that debug info, before I did that. Anyway this didn't solve my problem.
I even tried to make a small change in the main (latvian) product page and that change was not even reflected in the translation editor, it still appeared to be 100% translated and when I go to the english version of that product page then everything is empty.
What I changed (that part is selected in translation editor screencshot) - "Driksas upē" to "Driksā", but the translation editor still shows the old text "Driksas upē".
I also attached screenshot with the errors logs from the advanced translation editor. These logs are related to this issue, because url contains words from that problematic product.
August 22, 2024 at 12:05 pm #16094791
Andrey
Thank you for your feedback.
Could this problem be checked by temporarily deactivating all the plugins except WPML, WooCommerce Multilingual, and WooCommerce Multilingual & Multicurrency?
Does the same problem happen with a new product?
Please backup your database before making any changes.
August 22, 2024 at 7:57 pm #16096671
marcisL-2
Site owner
Ok, before I disabled any plugins I tried to create a completely new test product (check screenshot). And it works correctly. If I change something, even one digit, then click on update, then check the translation manager - this change is reflected there and translation works correctly. Product is translated to english successfully.
Then I disabled all plugins except the ones that you mentioned to keep active. First I didn't see any change - problem was the same as before (at least when I checked that problematic product I mentioned before). Then I made another change and for some reason changes were reflected in the product translation manager. I translated everything and the translation was applied and now there is an english translation for that product. After that I tried to make a few other small changes in the latvian text, but again - changes were not shown in the translation editor even with all of the non related plugins disabled.
I re-enabled all plugins and the problem is still there. I changed text in the translation editor (in the problematic product) , but the change is still not shown there, therefore, english translation is not being updated to the newest cahnges. I also noticed one warning when I went to the product's english version (see screenshot). I don't really know what that means, because translation appears 100% complete (however without the newest changes) and I also don't see anything special in this Translation Management dashboard.
August 23, 2024 at 5:07 pm #16099286
Andrey
Do you see the pencil status icon when you finish the translation? I suspect that one of the plugins on your installation is preventing translations from being downloaded. That could explain why you could see the change in the problematic product.
Does this happen with one existing product?
August 23, 2024 at 7:35 pm #16099523
marcisL-2
Site owner
Please see the screen recording: hidden link
This is the problematic product. I added one word to the end of the sentence, in the translation manager that word for some reason was nowhere to be found in that sentence. Anyway, clicked on complete translation and as you could see, there was a pencil icon near the english translation status.
I tried to do the same thing for a different product and I also was not able to see the change, when I added that same word in that same sentence. So I guess it is not only one specific product that is affected.
However, for some reason not all products are affected, because:
then I did the same thing for a third product, but there - no matter the change - translation manager showed all changes in text and worked correctly.
August 26, 2024 at 12:43 pm #16104555
Andrey
Thank you for your feedback. I have requested access to check the screen recording.
August 26, 2024 at 12:58 pm #16104605
marcisL-2
Site owner
Access has been granted
August 27, 2024 at 1:55 pm #16110398
Andrey
Thank you for the screencast.
I noticed that when you update the description text in the original product, the icon status doesn't update after you hit the "Update" button. However, the icon should be changed to a "circle," meaning the translation requires an update and something new has been added.
Maybe this product translation is being stuck somehow. Can you try the following?
- Make the same changes as in the screencast, but also temporarily change the title. For example, add a word to the description and a letter to the title, update the page, and see if it helps.
- If the above didn't help, go to WPML → Translation Management and resend the product to the translation.
August 28, 2024 at 9:07 pm #16117177
marcisL-2
Site owner
Well, changing the product title helped with detecting changes in product description. But the changes are only detected when I change the title. If I do not change the title then again no changes in product description are shown in the translation manager. So there is still some kind of bug that. Also my product variations in english version is messed up no matter how many times I update the translation (with or without the title change, they are not completely correct in product english version). I hadn't had these kind of issues up until around the august (at least then I started to notice that something is wrong). I don't know exactly if the wordpress version or what else changes around that time or a bit earlier, but something is broken and currently I am forced to hide option to change languages in my page, because it is better to not have that language at all than see broken products in english.
I again attached the screenshot of one of the WPML Advanced Translation Editor Error Logs. There are a lot of similar ones - maybe there is something you can see about what's broken from that error message.
August 29, 2024 at 8:45 am #16118557
Andrey
Thanks for your feedback and the screenshot. There are a few more steps to check:
1. Go to WPML → Translation Management → Translation Jobs and cancel the job that is in progress. If there's no job in progress, proceed to the next steps.
2. Make a slight change to the default page and update it (without a title change).
3. Go to WPML → Translation Management and add this page to the translation basket. Check the checkbox, scroll down, click "Translate," and then go to the translation basket tab.
4. In the translation basket, assign the page to yourself as a translator.
5. Navigate to WPML → Translations, select and translate the page. Once the translation is 100% complete, let's check if the correct content is displayed.
August 29, 2024 at 11:37 am #16119725
marcisL-2
Site owner
This approach worked. Even the broken product variations at some point translated correctly. But does this mean that I will have to these extra steps every single time I change the product description or product variations, because these changes are not detected in the translation manager that is in my product page.
August 29, 2024 at 12:47 pm #16120028
Andrey
These steps will help resolve the translation process for the product and allow it to function correctly.
I noticed that your WooCommerce plugin is installed, but it's running a very outdated version, which could be contributing to the issue.
Please ensure that you update WooCommerce, WooCommerce Multilingual & Multicurrency, and any other related plugins on your website.
https://wpml.org/account/downloads/
Remember to backup your database before proceeding.
September 1, 2024 at 8:46 pm #16129562
marcisL-2
Site owner
"These steps will help resolve the translation process for the product and allow it to function correctly."
Probably yes, but these are extra steps that take a few minutes every time and this time adds up. It would be really nice if the product WPML translation editor would recognise the changes in product variations or in the product description like it is supposed to. And I would not have to do all these extra steps every time, because we are changing product variations often enough.
I updated the WooCommerce plugin, but it did not fix the issue.
I remember when I previously had some problems with WPML and I contacted support, supporter was able to take a copy of my site and check the problems themselves. Maybe you can do something like that and maybe you could gather more information this way to solve this problem?
