You are trying to display products in a second language on your website using WPML, but the products do not show up in the second language even though they are translated.
We recommend checking if the translated products have timed prices set. If not, you should edit the translated products to add the timed prices and then update them. After making these changes, please verify if the products appear correctly in the second language.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket.
Last updated by 4 months, 3 weeks ago.
Assisted by: Osama Mersal.
