Last updated by Dražen 1 year, 12 months ago.
June 8, 2023 at 3:14 pm #13794213
mykolaL-4
Good day! I have programmatically created two products in different languages.
1) Are there any features for programmatically combining products?
2) Perhaps there is a way not to create two products separately, but to add one product and programmatically duplicate it for the desired language?
June 9, 2023 at 8:24 am #13797601
Dražen
1) Yes, you can use the next hook to update language information and connect translations:
- https://wpml.org/wpml-hook/wpml_set_element_language_details/
2) You can check the next hooks for duplicating posts:
- https://wpml.org/wpml-hook/wpml_make_post_duplicates/
- https://wpml.org/wpml-hook/wpml_admin_make_post_duplicates/
Other WPML hooks and filters you can use:
- https://wpml.org/documentation/support/wpml-coding-api/wpml-hooks-reference/
Hope it helps.
Drazen
The topic ‘[Closed] Programmatically duplicate/connecting products’ is closed to new replies.
