Last updated by Prosenjit Barman 10 months, 1 week ago.
March 29, 2024 at 8:24 am #15463331
nenadJ-5
I am using wpml with acf pro. I need to be able to automatically translate articles, but after translation set them to translate sepperatly after. When i try to remove some block on translated page i lose half of data
March 29, 2024 at 9:12 am #15463487
Prosenjit Barman
Hi There,
Here is your ticket. Please take your time to try the suggestion and share the update in response to this ticket. I'll be happy to help if you need further assistance in this matter.
Prosenjit
March 29, 2024 at 11:19 am #15464004
nenadJ-5
Hi, unfortunately this is not working. I will try to describe once again what we need.
So we have 4 languages on the website. English, slovenian, croatian and serbian. We are using automatic translations for the articles.
When we, for example write the original article in english, and want to translate it to serbian, we want the following to happen:
Automatic translation from english to serbian
WPML needs to copy all the translations and blocks we have in the article (all the texts, photos and links)
We need to have the ability to independetly change the blocks on serbian translation
For example, if we have one articles in english that consists of:
Block A
Block B
Block C
Block D
Block E
We want it to be copied to serbian and translated. But on serbian we want to be able to remove Block D. Right now we dont have that possibility.
Also when we use flexibile fields with translation option "translate", it doesn’t copy anything on serbian for example.
April 1, 2024 at 3:11 am #15467932
Prosenjit Barman
Hello There,
I hope you're doing well. Sorry for the delay in responding due to the weekend.
Thank you for the clarification. I completely understand what you're trying to achieve. If the translation preference for the Flexible field and its subfield is set to Translate, the field values should appear translated in other languages and also, you should be able to remove Fields independently from the translation.
Since you're having issues doing so, a closer inspection will be required to understand the root cause of the issue.
I would like to request temporary access (wp-admin and FTP) to your site along with the link to the page to take a better look at the issue. It would be better to have a testing site where the issue is replicated.
IMPORTANT
Best Regards,
Prosenjit
The topic ‘[Closed] Removing the Flexible block field removed other contents from the translated post’ is closed to new replies.
