Last updated by Andreas W. 1 year, 3 months ago.
February 1, 2024 at 11:39 am #15254626
orenv-3
We have a total 2 issues on my site
We are using "WPML SEO" and "Yoast SEO"
1) breadcum is not proper
2) The meta tag and meta description are wrong display
In English site meta tag and meta description german
can you please review it
Thank you
February 1, 2024 at 9:14 pm #15257055
Did you follow this guide to translate breadcrumbs?
https://wpml.org/documentation/plugins-compatibility/using-wordpress-seo-with-wpml/#translate-breadcrumbs
Did you translate the global SEO texts on WPML > String Translation:
https://wpml.org/documentation/plugins-compatibility/using-wordpress-seo-with-wpml/#translate-global-seo-texts
Regarding this please also take note of the following known issues:
https://wpml.org/errata/yoast-uncategorized-category-in-breadcrumbs-posts/
https://wpml.org/errata/title-disappears-using-the-automatic-translation/
https://wpml.org/errata/yoast-seo-meta-field-synchronization-does-not-work-for-fields-set-as-copy/
If further assistance is needed, please let me know.
February 2, 2024 at 6:30 am #15257802
orenv-3
We are using automatic translation in de language. after the translator site we are getting German text in eng language. Also we notice some German tags in the Yoast setting.
Do I reset Yoast date
please review it
Thank you
February 2, 2024 at 1:37 pm #15259569
IMPORTANT
I may have to install a plugin called "All In One WP Migration" to make a copy of the website where I can investigate the issue further.
However, I would also be very grateful if you could provide a staging site or copy of the website from your server yourself for this purpose.
If you have any questions about creating such a staging site, you can consult your hosting provider. Just take note that WPML should be registered on this site again.
If you are unable to provide such a copy of the site for testing, please let me know on this ticket.
Video:
February 6, 2024 at 12:00 pm #15271261
I can see that the breadcrumb issue appears to be solved already.
For the second issue:
You need to go to:
Here you see WPML > String Translation using the text domain:
admin_texts_wpseo_titles
First, you need to make sure to assign the German strings to the German source language, as German is your site's default language.
Guide:
https://wpml.org/documentation/getting-started-guide/string-translation/how-to-change-the-source-language-of-strings/
I did this already.
Then translate all the strings on this text domain.
I have completed some of those translations for you now and it works as expected.
Guide:
February 8, 2024 at 10:00 am #15280340
orenv-3
Yoast SEO displays other language then default language
February 8, 2024 at 11:58 am #15281010
orenv-3
We have a fetch language issue again for Beadcum and the meta title and meta description.
Our default language is English and we have translated in the German language.
German page have English data
can you please review and provide a solution for this
Thank you
February 8, 2024 at 2:59 pm #15281920
I went here:
I made sure that each string is assigned to the source language:
I translate all strings.
Please test again and if you still run into issues, then please provide me an example content by link or naming the content title and type.
February 12, 2024 at 5:28 am #15291015
orenv-3
I have checked this but still shows the same error. We need assistance for setting default language to english and translate to different language when required. As you can see the same in the attached screenshot. The german page showing english content.
It is good if you can take a call with us and we can sort these issues quickly, because we are facing many issues because of language in the website. Our SEO is getting affected the most.
Please let me know for your availability for call.
February 13, 2024 at 9:56 am #15296495
I would suggest that you delete the original German strings from WPML > String Translation and inside Yoast instead you use English text, as English is the site's default language.
The topic ‘[Closed] Site have language related issue with breadcrumb and meta title and description’ is closed to new replies.
