The client needs to display different decimal separators for invoices in English and German on a WooCommerce site, both using the Euro currency. The client found the necessary string for the decimal separator but it was registered and locked, preventing changes.
1. Set the default decimal separator in WooCommerce to a period (.) for English, which is the site's default language. Navigate to WooCommerce → Settings → General → Currency Options and set the Decimal Separator to a period (`.`).
2. To adjust the decimal separator for German, use WPML's String Translation. Go to WPML → String Translation and click on the Admin Texts Translation link here. Search for `woocommerce_price_decimal_sep`, check the box, and click "Add to String Translation".
3. In WPML → String Translation, search again for `woocommerce_price_decimal_sep`. For German, set the translation value to a comma (`,`), and leave the English version as is.
If this solution does not resolve your issue or seems outdated, we recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If further assistance is needed, please open a new support ticket here.
Last updated by Carlos Rojas 4 months ago.
Assisted by: Carlos Rojas.
May 2, 2025 at 11:16 am #16989300
simonM-37
I am trying to produce invoices in two languages, English and German, on my site hidden link. Both invoices are in the Euro currency. In WooCommerce, I have to choose a decimal separator as a point (.) or a comma (,).
I need English invoices to display the amount as €29.99 and German invoices to display it as €29,99 or 29,99 €.
Is it possible to have different decimal separators for English and German invoices in WooCommerce with the same currency (Euro €)?
May 2, 2025 at 1:45 pm #16989826
Bruno Kos
Since your site’s default language is English and you want to show different decimal separators for English and German invoices (while using Euro currency), here’s how you can set it up using WPML’s String Translation:
1. Go to WooCommerce → Settings → General → Currency Options
Set the Decimal Separator to a period (`.`)
This will apply to English (the default language)
2. Go to WPML → String Translation
At the bottom of the page, click on the Admin Texts Translation link https://wpml.org/documentation/getting-started-guide/string-translation/finding-strings-that-dont-appear-on-the-string-translation-page/#register-admin-and-setting-strings-for-translation
Check the box and click "Add to String Translation"
3. Back in WPML → String Translation, search for `woocommerce_price_decimal_sep`
Leave the English version unchanged (it will inherit the default value `.`)
Can you try this?
May 2, 2025 at 2:01 pm #16989860
simonM-37
Hi Bruno
I can find the string, but it is greyed out and disabled, so I can't check the box to add it to String Translation.
It says "Registered and locked" (see screenshot).
Please advise.
Kind regards
Simon
May 6, 2025 at 7:20 am #16999484
Carlos Rojas
WPML Supporter since 03/2017
Hello Simon,
The message you see means this string is already available in WPML -> String Translation. Please search and translate the string in WPML -> String Translation
Please let me know if you need further assistance.
May 6, 2025 at 9:59 pm #17003778
simonM-37
Gracias Carlos. Solved!
May 7, 2025 at 6:59 am #17004548
Carlos Rojas
Great!
Please don't hesitate to contact us if you need our help in the future with WPML.
Have an excellent day.
