Our next available supporter will start replying to tickets in about 6.16 hours from now. Thank you for your understanding.
Last updated by Long Nguyen 1 year, 10 months ago.
Assisted by: Long Nguyen.
January 15, 2023 at 7:39 am #12820203
Marketing Tech
This is our main site: corporatedev.gofluent.com
Here is the copied version of it: hidden link
To be more precise, we have created a recording instead on tackling our current issues:
2. Pages are being redirected to categories
January 15, 2023 at 7:43 am #12820211
Long Nguyen
It is possible the redirection is implemented by the plugin "Redirection" on your site. You can try to disable this plugin or enable a minimal environment as below and see if it helps.
- Deactivate all non-WPML plugins
- Switch to a standard theme of WordPress
You can use this plugin to create the backup:
https://wordpress.org/plugins/duplicator/
Look forward to your reply.
January 16, 2023 at 4:12 am #12823525
Marketing Tech
However, when checked, the redirection is being made by WPML and not our redirection plugin. We tried looking in all our set-up as well if we had one for this but there's none.
Thank you
January 16, 2023 at 6:39 am #12823875
Long Nguyen
Thank you for your feedback.
I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue. It would be better to a testing site where the issue is replicated. Your next reply is set to private to share the info.
The topic ‘[Closed] Split: Continuation of Redis Object Cache problem’ is closed to new replies.
