If you're experiencing issues with the default language in WordPress settings still being Dutch, and you need it to be in English, including the admin area.
We recommend changing the language of the admin in your profile settings. For detailed instructions, please refer to our guide on Setting the WordPress Administration Language.
Please note that this solution might be irrelevant if it's outdated or not applicable to your case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket at WPML support forum.
Last updated by Andrey 1 year, 1 month ago.
Assisted by: Andrey.
May 10, 2024 at 1:58 pm #15615181
bramv-19
a. default language in wordpress/settings/general is still dutch? so admin is also dutch? need it to be in english.
May 10, 2024 at 2:04 pm #15615188
Andrey
WPML Supporter since 06/2013
The language of the admin can be changed in your profile settings. Please refer to this guide: https://wpml.org/documentation/getting-started-guide/language-setup/setting-the-wordpress-administration-language/.
May 13, 2024 at 1:22 pm #15621114
bramv-19
i cannot change the admin language in the profile settings, as you could have seen in the screenshots.
May 13, 2024 at 2:01 pm #15621270
Andrey
The screenshots you provided are not from your profile settings. Please refer to the documentation I sent in the previous message for guidance.
