The client reported an issue where the product URL in English still showed parts in Finnish, despite being translated. Additionally, there were PHP warnings related to file access restrictions due to open_basedir settings on the server.
1. We initially attempted to debug the issue and requested a staging site or a duplicator copy from the client to safely investigate the problem further. https://wpml.org/fr/faq/provide-supporters-copy-site/
2. After initial checks, we escalated the issue to our second-tier support for deeper investigation.
3. We suggested the client ask their hosting provider to disable the open_basedir restrictions in the PHP settings to see if that resolves the permalink translation issue.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should you need further assistance, please do not hesitate to open a new support ticket at WPML support forum.
This topic is split from https://wpml.org/forums/topic/product-url-2/
| Author | Posts |
| April 3, 2025 at 6:16 am #16889875 | |
pamelaW |
Hi, I'm back again. One additional question regarding the product URL: in English: Is there still a conflict with the Product category base and Custom base: In English the product url has "standardi-tuotteet" still in Finnish though it is translated. (Images attached) On the Finnish product page hidden link, all breadcrumbs links are working. On the English product page hidden link only socket is working, but the "standard products" is not working due to this problem. Hope you still have time to help me! Kind regards, Pamela |
| April 3, 2025 at 6:34 am #16889964 | |
pamelaW |
Hi, have you changed to default theme? Can I change it back to Kadence? |
| April 3, 2025 at 6:48 am #16890049 | |
Dražen Supporter
Languages: English (English ) Timezone: Europe/Zagreb (GMT+02:00) |
Hello, yes, I need to debug issue further. I have reverted it now. Is there a way you can provide us a staging site where we can check this further? As I see some PHP warnings, it might be something related to the server. Also, if you can not provide a staging site, please provide a duplicator copy so I can check further safely. - https://wpml.org/fr/faq/provide-supporters-copy-site/ Regards, |
| April 3, 2025 at 7:02 am #16890080 | |
pamelaW |
Hi, |
| April 3, 2025 at 7:03 am #16890082 | |
pamelaW |
How can I submit the login to you? This ticket has no fields for that. |
| April 3, 2025 at 10:02 am #16891116 | |
Dražen Supporter
Hello, please provide it to the next private reply. Regards, |
| April 3, 2025 at 12:44 pm #16892263 | |
Dražen Supporter
Hello, thanks. I have checked but could not find a solution, so I have escalated to our 2nd tier to check further. I will update when I have some news, it can take a day or two. Regards, |
| April 3, 2025 at 1:10 pm #16892506 | |
pamelaW |
Hi, I hope you can solve it within some days. Kind regards, Pamela |
| April 3, 2025 at 1:24 pm #16892608 | |
Dražen Supporter
Hello Pamela, Please explain or share more info what do you mean by: "Our webhotel has also found this php-conflict so they are awared of it." Regards, |
| April 3, 2025 at 3:10 pm #16893402 | |
pamelaW |
Hi, here is a copy: Here are the PHP errors I mentioned. I looked into it more closely, and this error cannot be fixed by changing the server settings, because the plugin for some reason cannot find the path to that file at all, and instead, the plugin tries to access this path (which is not a path at all): File(WP Endpoints-de_DE.mo) The error originates from this file:: /var/www/vhosts/fpw.hostaan.name/httpdocs/sh/wp-content/plugins/wpml-string-translation/classes/MO/Hooks/LoadTranslationFile.php -> from row 82 forward DEV-site: [Thu Apr 03 11:17:15.923155 2025] [proxy_fcgi:error] [pid 2831678:tid 2831688] [client 94.237.10.42:0] AH01071: Got error 'PHP message: PHP Warning: file_exists(): open_basedir restriction in effect. File(WP Endpoints-en_US.mo) is not within the allowed path(s): (/var/www/vhosts/fpw.hostaan.name/:/tmp/) in /var/www/vhosts/fpw.hostaan.name/httpdocs/sh/wp-content/plugins/wpml-string-translation/classes/MO/Hooks/LoadTranslationFile.php on line 82; PHP message: PHP Warning: file_exists(): open_basedir restriction in effect. File(WP Endpoints-en_US.l10n.php) is not within the allowed path(s): (/var/www/vhosts/fpw.hostaan.name/:/tmp/) in /var/www/vhosts/fpw.hostaan.name/httpdocs/sh/wp-content/plugins/wpml-string-translation/classes/MO/Hooks/LoadTranslationFile.php on line 85; PHP message: PHP Warning: file_exists(): open_basedir restriction in effect. File(WP Endpoints-de_DE.mo) is not within the allowed path(s): (/var/www/vhosts/fpw.hostaan.name/:/tmp/) in /var/www/vhosts/fpw.hostaan.name/httpdocs/sh/wp-content/plugins/wpml-string-translation/classes/MO/Hooks/LoadTranslationFile.php on line 82; PHP message: PHP Warning: file_exists(): open_basedir restriction in effect. File(WP Endpoints-de_DE.l10n.php) is not within the allowed path(s): (/var/www/vhosts/fpw.hostaan.name/:/tmp/) in /var/www/vhosts/fpw.hostaan.name/httpdocs/sh/wp-content/plugins/wpml-string-translation/classes/MO/Hooks/LoadTranslationFile.php on line 85; PHP message: PHP Warning: file_exists(): open_basedir restriction in effect. File(WP Endpoints-sv_SE.mo) is not within the allowed path(s): (/var/www/vhosts/fpw.hostaan.name/:/tmp/) in /var/www/vhosts/fpw.hostaan.name/httpdocs/sh/wp-content/plugins/wpml-string-translation/classes/MO/Hooks/LoadTranslationFile.php on line 82; PHP message: PHP Warning: file_exists(): open_basedir restriction in effect. File(WP Endpoints-sv_SE.l10n.php) is not within the allowed path(s): (/var/www/vhosts/fpw.hostaan.name/:/tmp/) in /var/www/vhosts/fpw.hostaan.name/httpdocs/sh/wp-content/plugins/wpml-string-translation/classes/MO/Hooks/LoadTranslationFile.php on line 85' Production site: [Thu Apr 03 11:26:31.015032 2025] [proxy_fcgi:error] [pid 3926525:tid 3926576] [client 94.237.35.67:0] AH01071: Got error 'PHP message: PHP Warning: file_exists(): open_basedir restriction in effect. File(WP Endpoints-en_US.mo) is not within the allowed path(s): (/var/www/vhosts/sh-teksor.fi/:/tmp/) in /var/www/vhosts/sh-teksor.fi/httpdocs/wp-content/plugins/wpml-string-translation/classes/MO/Hooks/LoadTranslationFile.php on line 82; PHP message: PHP Warning: file_exists(): open_basedir restriction in effect. File(WP Endpoints-en_US.l10n.php) is not within the allowed path(s): (/var/www/vhosts/sh-teksor.fi/:/tmp/) in /var/www/vhosts/sh-teksor.fi/httpdocs/wp-content/plugins/wpml-string-translation/classes/MO/Hooks/LoadTranslationFile.php on line 85; PHP message: PHP Warning: file_exists(): open_basedir restriction in effect. File(WP Endpoints-fi.mo) is not within the allowed path(s): (/var/www/vhosts/sh-teksor.fi/:/tmp/) in /var/www/vhosts/sh-teksor.fi/httpdocs/wp-content/plugins/wpml-string-translation/classes/MO/Hooks/LoadTranslationFile.php on line 82; PHP message: PHP Warning: file_exists(): open_basedir restriction in effect. File(WP Endpoints-fi.l10n.php) is not within the allowed path(s): (/var/www/vhosts/sh-teksor.fi/:/tmp/) in /var/www/vhosts/sh-teksor.fi/httpdocs/wp-content/plugins/wpml-string-translation/classes/MO/Hooks/LoadTranslationFile.php on line 85; PHP message: PHP Warning: file_exists(): open_basedir restriction in effect. File(WP Endpoints-de_DE.mo) is not within the allowed path(s): (/var/www/vhosts/sh-teksor.fi/:/tmp/) in /var/www/vhosts/sh-teksor.fi/httpdocs/wp-content/plugins/wpml-string-translation/classes/MO/Hooks/LoadTranslationFile.php on line 82; PHP message: PHP Warning: file_exists(): open_basedir restriction in effect. File(WP Endpoints-de_DE.l10n.php) is not within the allowed path(s): (/var/www/vhosts/sh-teksor.fi/:/tmp/) in /var/www/vhosts/sh-teksor.fi/httpdocs/wp-content/plugins/wpml-string-translation/classes/MO/Hooks/LoadTranslationFile.php on line 85' |
| April 4, 2025 at 6:22 am #16895193 | |
Dražen Supporter
Hello, thanks for getting back. Can you please try/ask hosting to disable open_basedir restrictions from PHP settings and set them to none? Then try retranslate permalinks and let's see if that works. Regards, |
| April 4, 2025 at 12:21 pm #16897405 | |
pamelaW |
Hi, Kind regards, Pamela |
| April 4, 2025 at 12:34 pm #16897441 | |
Dražen Supporter
Hello Pamela, sure, have a nice weekend. Regards, |
| April 7, 2025 at 6:32 pm #16905801 | |
pamelaW |
Hi, |
| April 8, 2025 at 7:26 am #16907104 | |
Dražen Supporter
Hello, great, glad to hear that 🙂 For translation, sure, if you wish so. Actually, that path is a regular WPML/WP path for translation, so maybe restrictions should be modified from the hosting side to allow those folders also. But before, let me confirm on this with the 2nd tier if anything is wrong from our side. Regards, |
