1. The client's language switcher flags are not displaying.
2. When selecting the English language button, it redirects to the main page in Korean instead of the English version.
3. Using auto-translate does not translate all content, such as the main menu, and only parts of it are translated.
For the third issue regarding menu translation:
- If using the menu sync tool with auto-translate, custom links in the menu will not be automatically translated. To translate custom links, navigate to WPML > WP Menus Sync, click on sync, check for missing translations, and use the String Translation Tool. Here is a detailed guide on how to do this: Translating Menus.
- If translating menus manually, you may need to edit them in the desired language. The same documentation applies: Translating Menus Manually.
- If the issue persists, we request a screenshot of the menu editing screen from Appearance > Menus to identify the specific links not working as expected.
If this solution doesn't look relevant, please open a new support ticket at the WPML support forum.
This topic is split from https://wpml.org/forums/topic/i-operate-auto-translate-after-half-of-an-transtlate-it-stoped-at-0/
