You are experiencing an issue where the featured image set for a translated post disappears after some time, although it appears correctly in the original language.
If you are setting the Featured Image for the translated post directly in the WordPress editor, this might not be necessary. When you translate a post, the featured image from the original post is automatically copied and synchronized with the translation. If you wish to use a different featured image for each language, we recommend following the steps described in this documentation.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket.
Last updated by milijanM 5 months ago.
Assisted by: Andrey.
December 5, 2025 at 12:32 pm #17638461
milijanM
Another problem with Post translations:
For some unknown reason, when I select and set a Featured Image for a translated post, that image disappears after a while, I don't understand why?
The featured image appears in the original language (English) of the post...
December 5, 2025 at 12:43 pm #17638483
Andrey
WPML Supporter since 06/2013
I need a few more details to understand the situation better.
Do I understand correctly that you are setting the Featured Image for the translated page directly in the WordPress editor?
If so, this is not necessary. When you translate a post from the original page, the featured image is automatically copied and synchronized with the translation.
If your goal is to use a different featured image for each language, please follow the steps described in this article:
https://wpml.org/documentation/getting-started-guide/media-translation/#how-to-display-different-media-per-language
December 5, 2025 at 9:02 pm #17639731
milijanM
No, my goal is not to use a different image, I want it to use the same image as on the original page, but simply the images disappear by themselves. I use elementor to make pages!
December 8, 2025 at 2:54 pm #17644545
Andrey
Thank you for your feedback.
Could you please provide the exact steps you follow when doing this? I want to make sure I fully understand your workflow.
I’ve also enabled debug information for this support ticket. Please follow the instructions in the link below to retrieve the debug info from your site and share it with us:
December 8, 2025 at 6:16 pm #17645173
milijanM
Here are exact steps: hidden link
December 9, 2025 at 9:35 pm #17649554
Andrey
Thank you for providing the screencast.
What are the steps to make the Featured Image disappear for post translation? I have updated the post multiple times in the original language and the same in the translation, but the featured image is still there.
December 10, 2025 at 8:57 pm #17653887
milijanM
I don't even know, there were simply no photos and then I had to add them again and they disappeared again. I am saying this for the Serbian version of the site. Now I see you managed to get the photos back, may I know what you did?
December 11, 2025 at 3:48 pm #17656827
Andrey
I haven’t made any changes to your site regarding this issue. I simply logged in and opened the page you mentioned in the screencast. I noticed that the Serbian featured image is present.
To verify the problem, I updated the post several times in the original language and then did the same with the translation, checking whether the featured image would disappear. However, the featured image remains intact, and I’m not able to reproduce the issue on your site.
December 11, 2025 at 9:10 pm #17657574
milijanM
Ok, in that case we can close this Post.
