The client is experiencing issues with some translated links not working, specifically from the Payroll section in the menu and other links listed from the homepage.
If you're encountering similar issues with translated links not functioning correctly, we recommend the following steps:
1. Ensure that you have completed the translation for each page.
2. Test the steps provided in any previous support tickets related to this issue.
3. Temporarily deactivate all plugins except for WPML to check if the issue persists. This can help identify if any other plugin is causing a conflict.
4. Enable debug information to provide more insights into what might be causing the issue. You can find instructions on how to do this here: http://wpml.org/faq/provide-debug-information-faster-support/.
Before proceeding with these steps, ensure to back up your database to prevent any data loss.
If these steps do not resolve the issue, or if the solution seems outdated or irrelevant to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket with us for further assistance.
Last updated by andreeaN-3 1 week, 5 days ago.
Assisted by: Andrey.
March 28, 2025 at 7:47 pm #16874463
andreeaN-3
I have another question, why do the translated links work, some do not?
For example:
This works, but from Payroll in the menu, below, they do not open.
Or from the homepage:
Payroll - hidden link
Tax residence - hidden link
Outplacement - hidden link
What should I do?
March 28, 2025 at 7:54 pm #16874474
Andrey
I’m sorry you ran into trouble with this. I need a little more information to understand what’s happening.
Have you completed the page translation? Have you tested the steps outlined in the previous support ticket?
Does the same issue occur if you temporarily turn off all plugins except WPML?
I have enabled debug information for this support ticket. Please refer to this link for instructions on retrieving this information from your site and provide it to us: http://wpml.org/faq/provide-debug-information-faster-support/.
Before making any changes, please back up your database first.
March 29, 2025 at 8:20 am #16874977
andreeaN-3
I have disabled all plugins, but still, nothing is displayed.
I would try in En for now, maybe in It, it does the same.
If I want to see the preview, it works, it can be seen. hidden link
Mai jos regasiti codul debug:
{"core":{"Wordpress":{"Multisite":"No","SiteURL":"https:\/\/www.solutiiresurseumane.ro","HomeURL":"https:\/\/www.solutiiresurseumane.ro","Version":"6.7.2","PermalinkStructure":"\/%postname%\/","PostTypes":"post, page, attachment, revision, nav_menu_item, custom_css, customize_changeset, oembed_cache, user_request, wp_block, wp_template, wp_template_part, wp_global_styles, wp_navigation, wp_font_family, wp_font_face, elementor_library, acf-taxonomy, acf-post-type, acf-field-group, acf-field, wpcf7_contact_form, job_listing, teams, portfolios, testimonials, events, rselements_pro","PostStatus":"publish, future, draft, pending, private, trash, auto-draft, inherit, request-pending, request-confirmed, request-failed, request-completed, acf-disabled","RestEnabled":"Yes"},"Server":{"jQueryVersion":"3.7.1","PHPVersion":"7.4.33","MySQLVersion":"10.3.39","ServerSoftware":"LiteSpeed"},"PHP":{"MemoryLimit":"512M","WP Memory Limit":"40M","UploadMax":"128M","PostMax":"512M","TimeLimit":"90","MaxInputVars":"1000","MBString":true,"libxml":true}},"plugins":{"active_plugins":{"sitepress-multilingual-cms\/sitepress.php":{"Plugin Slug":"sitepress-multilingual-cms","Requires Yoast SEO":"","Name":"WPML Multilingual CMS","PluginURI":"https:\/\/wpml.org\/","Version":"4.7.2","Author":"OnTheGoSystems","AuthorURI":"http:\/\/www.onthegosystems.com\/","TextDomain":"sitepress-multilingual-cms","DomainPath":"","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"WPML Multilingual CMS","AuthorName":"OnTheGoSystems"},"redux-framework\/redux-framework.php":{"Plugin Slug":"","Requires Yoast SEO":"","Name":"Redux Framework","PluginURI":"https:\/\/wordpress.org\/plugins\/redux-framework","Version":"4.5.7","Author":"Team Redux","AuthorURI":"https:\/\/redux.io","TextDomain":"redux-framework","DomainPath":"","Network":false,"RequiresWP":"5.0","RequiresPHP":"7.4","UpdateURI":"","RequiresPlugins":"","Title":"Redux Framework","AuthorName":"Team Redux"},"wp-seo-multilingual\/plugin.php":{"Plugin Slug":"wp-seo-multilingual","Requires Yoast SEO":"","Name":"WPML SEO","PluginURI":"https:\/\/wpml.org\/","Version":"2.1.1","Author":"OnTheGoSystems","AuthorURI":"http:\/\/www.onthegosystems.com\/","TextDomain":"wp-seo-multilingual","DomainPath":"","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"WPML SEO","AuthorName":"OnTheGoSystems"},"advanced-custom-fields\/acf.php":{"Plugin Slug":"","Requires Yoast SEO":"","Name":"Advanced Custom Fields","PluginURI":"https:\/\/www.advancedcustomfields.com","Version":"6.3.12","Author":"WP Engine","AuthorURI":"https:\/\/wpengine.com\/?utm_source=wordpress.org\u0026utm_medium=referral\u0026utm_campaign=plugin_directory\u0026utm_content=advanced_custom_fields","TextDomain":"acf","DomainPath":"\/lang","Network":false,"RequiresWP":"6.0","RequiresPHP":"7.4","UpdateURI":"","RequiresPlugins":"","Title":"Advanced Custom Fields","AuthorName":"WP Engine"},"breadcrumb-navxt\/breadcrumb-navxt.php":{"Plugin Slug":"","Requires Yoast SEO":"","Name":"Breadcrumb NavXT","PluginURI":"http:\/\/mtekk.us\/code\/breadcrumb-navxt\/","Version":"7.4.1","Author":"John Havlik","AuthorURI":"http:\/\/mtekk.us\/","TextDomain":"breadcrumb-navxt","DomainPath":"\/languages","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"Breadcrumb NavXT","AuthorName":"John Havlik"},"classic-editor\/classic-editor.php":{"Plugin Slug":"","Requires Yoast SEO":"","Name":"Classic Editor","PluginURI":"https:\/\/wordpress.org\/plugins\/classic-editor\/","Version":"1.6.7","Author":"WordPress Contributors","AuthorURI":"https:\/\/github.com\/WordPress\/classic-editor\/","TextDomain":"classic-editor","DomainPath":"\/languages","Network":false,"RequiresWP":"4.9","RequiresPHP":"5.2.4","UpdateURI":"","RequiresPlugins":"","Title":"Classic Editor","AuthorName":"WordPress Contributors"},"contact-form-7-multilingual\/plugin.php":{"Plugin Slug":"contact-form-7-multilingual","Requires Yoast SEO":"","Name":"Contact Form 7 Multilingual","PluginURI":"","Version":"1.3.2","Author":"OnTheGoSystems","AuthorURI":"http:\/\/www.onthegosystems.com\/","TextDomain":"contact-form-7-multilingual","DomainPath":"","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"Contact Form 7 Multilingual","AuthorName":"OnTheGoSystems"},"contact-form-7\/wp-contact-form-7.php":{"Plugin Slug":"","Requires Yoast SEO":"","Name":"Contact Form 7","PluginURI":"https:\/\/contactform7.com\/","Version":"6.0.5","Author":"Takayuki Miyoshi","AuthorURI":"https:\/\/ideasilo.wordpress.com\/","TextDomain":"contact-form-7","DomainPath":"","Network":false,"RequiresWP":"6.6","RequiresPHP":"7.4","UpdateURI":"","RequiresPlugins":"","Title":"Contact Form 7","AuthorName":"Takayuki Miyoshi"},"cookie-law-info\/cookie-law-info.php":{"Plugin Slug":"","Requires Yoast SEO":"","Name":"CookieYes | GDPR Cookie Consent","PluginURI":"https:\/\/www.cookieyes.com\/","Version":"3.2.9","Author":"CookieYes","AuthorURI":"https:\/\/www.cookieyes.com\/","TextDomain":"cookie-law-info","DomainPath":"","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"CookieYes | GDPR Cookie Consent","AuthorName":"CookieYes"},"custom-post-type-ui\/custom-post-type-ui.php":{"Plugin Slug":"","Requires Yoast SEO":"","Name":"Custom Post Type UI","PluginURI":"https:\/\/github.com\/WebDevStudios\/custom-post-type-ui\/","Version":"1.17.2","Author":"WebDevStudios","AuthorURI":"https:\/\/webdevstudios.com\/","TextDomain":"custom-post-type-ui","DomainPath":"\/languages","Network":false,"RequiresWP":"6.5","RequiresPHP":"7.4","UpdateURI":"","RequiresPlugins":"","Title":"Custom Post Type UI","AuthorName":"WebDevStudios"},"duplicate-page\/duplicatepage.php":{"Plugin Slug":"","Requires Yoast SEO":"","Name":"Duplicate Page","PluginURI":"https:\/\/wordpress.org\/plugins\/duplicate-page\/","Version":"4.5.4","Author":"mndpsingh287","AuthorURI":"https:\/\/profiles.wordpress.org\/mndpsingh287\/","TextDomain":"duplicate-page","DomainPath":"","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"Duplicate Page","AuthorName":"mndpsingh287"},"elementor\/elementor.php":{"Plugin Slug":"","Requires Yoast SEO":"","Name":"Elementor","PluginURI":"https:\/\/elementor.com\/?utm_source=wp-plugins\u0026utm_campaign=plugin-uri\u0026utm_medium=wp-dash","Version":"3.28.1","Author":"Elementor.com","AuthorURI":"https:\/\/elementor.com\/?utm_source=wp-plugins\u0026utm_campaign=author-uri\u0026utm_medium=wp-dash","TextDomain":"elementor","DomainPath":"","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"Elementor","AuthorName":"Elementor.com"},"envato-market\/envato-market.php":{"Plugin Slug":"","Requires Yoast SEO":"","Name":"Envato Market","PluginURI":"https:\/\/envato.com\/market-plugin\/","Version":"2.0.12","Author":"Envato","AuthorURI":"https:\/\/envato.com","TextDomain":"envato-market","DomainPath":"\/languages\/","Network":false,"RequiresWP":"5.1","RequiresPHP":"7.0","UpdateURI":"","RequiresPlugins":"","Title":"Envato Market","AuthorName":"Envato"},"google-site-kit\/google-site-kit.php":{"Plugin Slug":"","Requires Yoast SEO":"","Name":"Site Kit by Google","PluginURI":"https:\/\/sitekit.withgoogle.com","Version":"1.149.1","Author":"Google","AuthorURI":"https:\/\/opensource.google.com","TextDomain":"google-site-kit","DomainPath":"","Network":false,"RequiresWP":"5.2","RequiresPHP":"7.4","UpdateURI":"","RequiresPlugins":"","Title":"Site Kit by Google","AuthorName":"Google"},"litespeed-cache\/litespeed-cache.php":{"Plugin Slug":"","Requires Yoast SEO":"","Name":"LiteSpeed Cache","PluginURI":"https:\/\/www.litespeedtech.com\/products\/cache-plugins\/wordpress-acceleration","Version":"7.0.0.1","Author":"LiteSpeed Technologies","AuthorURI":"https:\/\/www.litespeedtech.com","TextDomain":"litespeed-cache","DomainPath":"\/lang","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"LiteSpeed Cache","AuthorName":"LiteSpeed Technologies"},"one-click-demo-import\/one-click-demo-import.php":{"Plugin Slug":"","Requires Yoast SEO":"","Name":"One Click Demo Import","PluginURI":"https:\/\/wordpress.org\/plugins\/one-click-demo-import\/","Version":"3.3.0","Author":"OCDI","AuthorURI":"https:\/\/ocdi.com","TextDomain":"one-click-demo-import","DomainPath":"\/languages","Network":false,"RequiresWP":"5.5","RequiresPHP":"5.6","UpdateURI":"","RequiresPlugins":"","Title":"One Click Demo Import","AuthorName":"OCDI"},"revslider\/revslider.php":{"Plugin Slug":"","Requires Yoast SEO":"","Name":"Slider Revolution","PluginURI":"https:\/\/www.sliderrevolution.com\/?utm_source=admin\u0026utm_medium=button\u0026utm_campaign=srusers\u0026utm_content=info","Version":"6.7.17","Author":"ThemePunch","AuthorURI":"https:\/\/themepunch.com\/?utm_source=admin\u0026utm_medium=button\u0026utm_campaign=srusers\u0026utm_content=info","TextDomain":"revslider","DomainPath":"\/languages","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"Slider Revolution","AuthorName":"ThemePunch"},"rs_framework\/rs-framework.php":{"Plugin Slug":"","Requires Yoast SEO":"","Name":"RS Framework","PluginURI":"https:\/\/codecanyon.net\/user\/rs-theme","Version":"2.0.3","Author":"RS Theme","AuthorURI":"http:\/\/www.rstheme.com","TextDomain":"rs_framework","DomainPath":"","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"RS Framework","AuthorName":"RS Theme"},"rselements\/rs-addon.php":{"Plugin Slug":"","Requires Yoast SEO":"","Name":"RSElements","PluginURI":"https:\/\/rstheme.com\/","Version":"2.0.3","Author":"rs-theme","AuthorURI":"https:\/\/rstheme.com\/","TextDomain":"rsaddon","DomainPath":"","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"RSElements","AuthorName":"rs-theme"},"tinymce-advanced\/tinymce-advanced.php":{"Plugin Slug":"","Requires Yoast SEO":"","Name":"Advanced Editor Tools","PluginURI":"https:\/\/wordpress.org\/plugins\/tinymce-advanced\/","Version":"5.9.2","Author":"Automattic","AuthorURI":"https:\/\/automattic.com","TextDomain":"tinymce-advanced","DomainPath":"","Network":false,"RequiresWP":"5.9","RequiresPHP":"5.6","UpdateURI":"","RequiresPlugins":"","Title":"Advanced Editor Tools","AuthorName":"Automattic"},"ultimate-coming-soon\/ultimate-coming-soon-maintenance.php":{"Plugin Slug":"","Requires Yoast SEO":"","Name":"Ultimate Coming Soon \u0026 Maintenance","PluginURI":"https:\/\/wordpress.org\/plugins\/ultimate-coming-soon\/","Version":"1.1.1","Author":"RSTheme","AuthorURI":"http:\/\/rstheme.com","TextDomain":"ultimate-coming-soon","DomainPath":"\/languages","Network":false,"RequiresWP":"5.5","RequiresPHP":"7.0.0","UpdateURI":"","RequiresPlugins":"","Title":"Ultimate Coming Soon \u0026 Maintenance","AuthorName":"RSTheme"},"updraftplus\/updraftplus.php":{"Plugin Slug":"","Requires Yoast SEO":"","Name":"UpdraftPlus - Backup\/Restore","PluginURI":"https:\/\/updraftplus.com","Version":"1.25.3","Author":"TeamUpdraft, DavidAnderson","AuthorURI":"https:\/\/updraftplus.com","TextDomain":"updraftplus","DomainPath":"\/languages","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"UpdraftPlus - Backup\/Restore","AuthorName":"TeamUpdraft, DavidAnderson"},"wordfence\/wordfence.php":{"Plugin Slug":"","Requires Yoast SEO":"","Name":"Wordfence Security","PluginURI":"https:\/\/www.wordfence.com\/","Version":"8.0.4","Author":"Wordfence","AuthorURI":"https:\/\/www.wordfence.com\/","TextDomain":"wordfence","DomainPath":"\/languages","Network":true,"RequiresWP":"4.7","RequiresPHP":"7.0","UpdateURI":"","RequiresPlugins":"","Title":"Wordfence Security","AuthorName":"Wordfence"},"wordpress-seo-premium\/wp-seo-premium.php":{"Plugin Slug":"","Requires Yoast SEO":"24.7","Name":"Yoast SEO Premium","PluginURI":"https:\/\/yoa.st\/2jc","Version":"24.7","Author":"Team Yoast","AuthorURI":"https:\/\/yoa.st\/team-yoast-premium","TextDomain":"wordpress-seo-premium","DomainPath":"\/languages\/","Network":false,"RequiresWP":"6.6","RequiresPHP":"7.2.5","UpdateURI":"","RequiresPlugins":"","Title":"Yoast SEO Premium","AuthorName":"Team Yoast"},"wordpress-seo\/wp-seo.php":{"Plugin Slug":"","Requires Yoast SEO":"","Name":"Yoast SEO","PluginURI":"https:\/\/yoa.st\/1uj","Version":"24.7","Author":"Team Yoast","AuthorURI":"https:\/\/yoa.st\/1uk","TextDomain":"wordpress-seo","DomainPath":"\/languages\/","Network":false,"RequiresWP":"6.6","RequiresPHP":"7.2.5","UpdateURI":"","RequiresPlugins":"","Title":"Yoast SEO","AuthorName":"Team Yoast"},"wpml-cms-nav\/plugin.php":{"Plugin Slug":"wpml-cms-nav","Requires Yoast SEO":"","Name":"WPML CMS Nav","PluginURI":"https:\/\/wpml.org\/","Version":"1.5.5","Author":"OnTheGoSystems","AuthorURI":"http:\/\/www.onthegosystems.com\/","TextDomain":"wpml-cms-nav","DomainPath":"","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"WPML CMS Nav","AuthorName":"OnTheGoSystems"},"wpml-string-translation\/plugin.php":{"Plugin Slug":"wpml-string-translation","Requires Yoast SEO":"","Name":"WPML String Translation","PluginURI":"https:\/\/wpml.org\/","Version":"3.3.2","Author":"OnTheGoSystems","AuthorURI":"http:\/\/www.onthegosystems.com\/","TextDomain":"wpml-string-translation","DomainPath":"","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"WPML String Translation","AuthorName":"OnTheGoSystems"}},"mu_plugins":[],"dropins":[]},"theme":{"Name":"Reobiz Child","ThemeURI":false,"Author":"RS Theme","AuthorURI":"http:\/\/rstheme.com","Template":"reobiz","Version":"5.0.0","TextDomain":"","DomainPath":"","ParentName":"Reobiz"},"extra-debug":{"WPML(setup)":{"is-tm-allowed":true,"original-lang":"ro","who-mode":["service"],"translated-langs":["en","it"],"current-step":"plugins","translate-everything":false,"review-mode":"publish-and-review"},"WPML":{"hide_upgrade_notice":"4.7.2","translated_document_status_sync":"1","icl_capabilities_verified":true,"active_languages":["en","it","ro"],"interview_translators":1,"existing_content_language_verified":1,"language_negotiation_type":1,"icl_lso_link_empty":1,"sync_page_ordering":1,"sync_page_parent":1,"sync_page_template":1,"sync_ping_status":1,"sync_comment_status":1,"sync_sticky_flag":1,"sync_password":1,"sync_private_flag":1,"sync_post_format":1,"sync_delete":0,"sync_delete_tax":0,"sync_post_taxonomies":1,"sync_post_date":1,"sync_taxonomy_parents":0,"translation_pickup_method":0,"notify_complete":1,"translated_document_status":"1","remote_management":0,"auto_adjust_ids":1,"alert_delay":0,"promote_wpml":0,"automatic_redirect":0,"remember_language":24,"icl_lang_sel_copy_parameters":"","translated_document_page_url":"translate","sync_comments_on_duplicates":0,"seo":{"head_langs":1,"canonicalization_duplicates":1,"head_langs_priority":1},"posts_slug_translation":{"on":1,"string_name_migrated":true},"urls":{"directory_for_default_language":0,"show_on_root":"","root_html_file_path":"","root_page":0,"hide_language_switchers":1},"xdomain_data":1,"custom_posts_sync_option":{"post":1,"page":1,"attachment":1,"wp_block":1,"wp_navigation":1,"wp_template":1,"wp_template_part":1,"acf-post-type":0,"acf-taxonomy":0,"acf-ui-options-page":0,"wpcf7_contact_form":1,"cookielawinfo":1,"elementor_library":1,"e-landing-page":2,"e-floating-buttons":2,"mc4wp-form":1,"teams":1,"portfolios":1,"testimonials":1,"rselements_pro":1},"taxonomies_sync_option":{"category":1,"post_tag":1,"translation_priority":1,"wp_theme":0,"cookielawinfo-category":1,"elementor_library_type":0,"team-category":1,"portfolio-category":1,"testimonial-category":1},"tm_block_retranslating_terms":1,"admin_default_language":"_default_","ajx_health_checked":true,"st":{"autoregister_strings":0,"db_ok_for_gettext_context":true,"WPML_ST_Upgrade_MO_Scanning_4_has_run":true,"strings_per_page":10,"icl_st_auto_reg":"disable","strings_language":"en","translated-users":[],"WPML\\ST\\MO\\Generate\\Process\\Status_has_run":true,"sw":[],"WPML\\ST\\MO\\Generate\\Process\\Status_background_has_run":true,"WPML_ST_Upgrade_DB_String_Packages_Word_Count_has_run":true,"WPML_ST_Upgrade_DB_String_Packages_Translator_Note_has_run":true,"WPML_ST_Upgrade_Migrate_Originals_has_run":true,"WPML_ST_Upgrade_Display_Strings_Scan_Notices_has_run":true,"WPML_ST_Upgrade_DB_String_Packages_2.4.2_has_run":true,"WPML_ST_Upgrade_DB_String_Name_Index_2_has_run":true,"WPML_ST_Upgrade_DB_Longtext_String_Value_has_run":true,"WPML_ST_Upgrade_DB_Strings_Add_Translation_Priority_Field_has_run":true,"WPML\\ST\\Upgrade\\Command\\RegenerateMoFilesWithStringNames_has_run":true,"WPML\\ST\\Upgrade\\Command\\MigrateMultilingualWidgets_has_run":true,"WPML\\ST\\Upgrade\\Command\\UpgradeAutoregisteringStrings_has_run":true,"autoregister_strings_should_register_backend_strings":false,"was_frontend_visited_key":1},"translation_service":{"id":12,"logo_url":"https:\/\/tp-cdn.wpml.org\/production\/logos\/blend-c1b22a6aa7c2759075ed.png","logo_preview_url":"https:\/\/tp-cdn.wpml.org\/production\/logos\/preview_blend-c1b22a6aa7c2759075ed.png","name":"BLEND","description":"BLEND is a global localization service provider brought by the makers of OneHourTranslation. As an end-to-end AI-powered multi-market enabler, BLEND is empowering global brands to establish a native presence in fundamentally different markets, worldwide.","doc_url":"https:\/\/wpml.org\/translation-service\/blend\/","tms":false,"partner":true,"custom_fields":{"custom_fields":[{"label":"Secret Key","name":"secret_key","type":"text"},{"label":"Public Key","name":"public_key","type":"text"}]},"custom_fields_data":{"public_key":"NcFZQqG3vLgBWDj9nztP","secret_key":"04ffbfa609ff6fbd4fe6808c0b1c6ca5"},"requires_authentication":true,"rankings":{"quality":0,"quality_ranking":0,"speed":2,"speed_ranking":2235,"popularity":4,"popularity_ranking":27.08,"primary":5,"primary_ranking":27.08},"has_language_pairs":true,"url":"https:\/\/app.getblend.com\/affiliate\/wpml_otgs","project_details_url":"https:\/\/app.getblend.com\/my-projects\/customer\/","add_language_pair_url":"","custom_text_url":"","select_translator_iframe_url":"","translator_contact_iframe_url":"","quote_iframe_url":"","has_translator_selection":false,"project_name_length":128,"suid":"8850fd4bfdaae2a2d63e51fb1f2ac3e4","notification":true,"preview_bundle":null,"deadline":true,"oauth":false,"oauth_url":"","default_service":0,"translation_feedback":true,"feedback_forward_method":"email","last_refresh":1743188803,"popup_message":"\u003Ca href=\u0022https:\/\/app.getblend.com\/affiliate\/wpml_otgs\u0022 target=\u0022_blank\u0022\u003ERegister\u003C\/a\u003E to BLEND to generate your API Keys.\u003Cbr \/\u003EAlready have an account? Log-in and \u003Ca href=\u0022https:\/\/wpml.org\/go\/blend\/\u0022 target=\u0022_blank\u0022\u003Eget your token\u003C\/a\u003E.","how_to_get_credentials_desc":"Your Secret Key and Public Key are located under \u0022Profile \u003E API Keys\u0022 on your OneHourTranslation Control panel","how_to_get_credentials_url":"https:\/\/wpml.org\/translation-service\/onehourtranslation\/#api-secret-public-keys","client_create_account_page_url":"https:\/\/wpml.org\/translation-service\/onehourtranslation\/#create-account","redirect_to_ts":true,"countries":[{"name":"Israel","code":"IL"},{"name":"Romania","code":"RO"},{"name":"Ukraine","code":"UA"},{"name":"United States","code":"US"},{"name":"China","code":"CN"},{"name":"Taiwan, Province of China","code":"TW"},{"name":"United Kingdom","code":"GB"}],"maximumJobsPerBatch":0,"languages_map":{"af":"af","am":"am-et","en":"en-us","sq":"sq-al","ar":"ar-sa","fr":"fr-fr","he":"he-il","it":"it-it","ru":"ru-ru","es":"es-es","tr":"tr-tr","ur":"ur-pk","ar-eg":"ar-eg","ar-ae":"ar-ae","ar-jo":"ar-jo","ar-ma":"ar-ma","hy":"hy-am","az":"az-az","eu":"baq","be":"be-by","bn":"bn-bd","bs":"bs-ba","bg":"bg-bg","my":"my-mm","ca":"ca-es","de":"de-de","zh-hant":"zh-cn-cmn-t","zh-hans":"zh-cn-cmn-s","ko":"ko-kp","zh-tw":"zh-tw","uk":"uk-ua","zh":"zh-cn-yue","hr":"hr-hr","sl":"sl-si","cs":"cs-cz","sk":"sk-sk","da":"da","no":"no-no","sv":"sv-se","fa-af":"fa-af","ps":"ps","nl":"nl-nl","fl-be":"fl-be","es-ar":"es-ar","et":"et-ee","fi":"fi-fi","fr-ca":"fr-ca","ka":"ka-ge","el":"el-gr","gu":"gu-in","ht":"ht","hi":"hi-in","hu":"hu-hu","is":"is-is","id":"id-id","ga-ie":"ga-ie","ja":"ja-jp","kn":"kn","kk":"kk-kz","km":"km-kh","ku":"ku-tr","lo":"lo-la","lv":"lv-lv","lt":"lt-lt","mk":"mk-mk","ms":"ms-my","ml":"ml-in","mr":"mr-in","mn":"mn-mn","ne":"ne-np","fa":"fa-ir","pl":"pl-pl","pt-br":"pt-br","pt-pt":"pt-pt","ro":"ro-ro","sr":"sr","si":"si","sw":"sw","fr-ch":"fr-ch","it-ch":"it-ch","tl":"tl-ph","ta":"ta-in","te":"te-in","th":"th-th","ti":"tir","uz":"uz-uz","vi":"vi-vn","cy":"cy-bg","xh":"xho","yo":"yo-ng","zu":"zul","es-la":"es-la"}},"translator_choice":false,"icl_lang_status":false,"icl_html_status":false,"icl_current_session":false,"last_icl_reminder_fetch":false,"translators_management_info":false,"language_pairs":false,"icl_translation_projects":{"e7d4ddbee4c1a4966b7c55682bdb6840":{"id":20111,"access_key":"140e8524ead7fb25c63f294ae29ba40443c74d98a78e57302cdb77719cee4cf9","ts_id":null,"ts_access_key":null,"extra_fields":[{"name":"expertise","label":"Please choose an expertise","type":"select","items":{"-1":"General","general":"General","automotive-aerospace":"Automotive \/ Aerospace","business-finance":"Finance","software-it":"Software \/ IT","legal-certificate":"Legal","marketing-consumer-media":"Marketing \/ Consumer\/ Media","medical":"Medical","patents":"Patents","scientific-academic":"Scientific \/ Academic","technical-engineering":"Technical \/ Engineering","gaming-video-games":"Gaming \/ Video Games","ad-words-banners":"Ad-Words \/ Banners","mobile-applications":"Mobile Applications","tourism":"Tourism","certificates-translation":"Certificates Translation","training-employee-handbooks":"Training \/ Employee Handbooks","forex-crypto":"Forex \/ Crypto"}}]}},"default_categories":{"ro":"103","en":1,"it":277},"default_language":"ro","setup_wizard_step":3,"languages_order":["ro","en","it"],"dont_show_help_admin_notice":true,"store_frontend_cookie":1,"setup_complete":1,"admin_text_3_2_migration_complete_90265a32b5902226246850025d0c45e0":true,"admin_text_3_2_migration_complete_3b12fc7441517682711b1f5196c11c1a":true,"admin_text_3_2_migration_complete_641ba3f9cbee90861c9d7a9e81994467":true,"admin_text_3_2_migration_complete_b6371a0ccef5c2b2e4a8e0a857fd641a":true,"admin_text_3_2_migration_complete_29cff6a3954be9dc8f8e521f80f4be91":true,"translation-management":{"custom_fields_translation":{"title":2,"description":2,"keywords":2,"_edit_last":2,"_edit_lock":2,"_wp_page_template":2,"_wp_attachment_metadata":2,"original_post_id":0,"_wpml_original_post_id":0,"_wp_old_slug":0,"_icl_translator_note":0,"_alp_processed":0,"_pingme":0,"_encloseme":0,"_icl_lang_duplicate_of":0,"_thumbnail_id":2,"_wp_attached_file":2,"_wp_attachment_image_alt":2,"footnotes":2,"_yoast_wpseo_title":2,"_yoast_wpseo_bctitle":2,"_yoast_wpseo_metadesc":2,"_yoast_wpseo_metakeywords":2,"_yoast_wpseo_focuskw":2,"_yoast_wpseo_focuskeywords":2,"_yoast_wpseo_meta-robots-noindex":1,"_yoast_wpseo_meta-robots-nofollow":1,"_yoast_wpseo_meta-robots-adv":1,"_yoast_wpseo_canonical":0,"_yoast_wpseo_redirect":0,"_yoast_wpseo_opengraph-description":2,"_yoast_wpseo_google-plus-description":2,"_yoast_wpseo_twitter-title":2,"_yoast_wpseo_twitter-description":2,"_yoast_wpseo_opengraph-title":2,"_yoast_wpseo_opengraph-image":3,"_yoast_wpseo_twitter-image":3,"_yoast_wpseo_primary_category":1,"_yoast_wpseo_primary_product_cat":1,"_form":2,"_mail":2,"_mail_2":2,"_messages":2,"_additional_settings":1,"_locale":1,"_elementor_page_settings":2,"_elementor_edit_mode":2,"_elementor_template_type":2,"_elementor_version":2,"_elementor_data":3,"_elementor_css":0,"_elementor_popup_display_settings":3,"_mc4wp_settings":3,"text_subscribed":2,"text_error":2,"text_invalid_email":2,"text_already_subscribed":2,"text_required_field_missing":2,"text_unsubscribed":2,"text_not_subscribed":2,"text_no_lists_selected":2,"_yoast_wpseo_keyword":2,"_cms_nav_minihome":1,"_cms_nav_section":2,"_top_nav_excluded":1,"_attachment_original_parent_id":2,"_menu_item_type":2,"_menu_item_menu_item_parent":2,"_menu_item_object_id":2,"_menu_item_object":2,"_menu_item_target":2,"_menu_item_classes":2,"_menu_item_xfn":2,"_menu_item_url":2,"_oembed_4321638fc1a6fee26443f7fe8a70a871":2,"_oembed_29351fff85c1be1d1e9a965a0332a861":2,"_oembed_9fcc86d7d9398ff736577f922307f64d":2,"_oembed_366237792d32461d0052efb2edec37f5":2,"_oembed_37fdfe862c13c46a93be2921279bf675":2,"enclosure":2,"_oembed_time_d01e104b758ab65a49dfdede5913069c":2,"_oembed_ac49b172e1844531a885a53eff2efd91":2,"_oembed_time_ac49b172e1844531a885a53eff2efd91":2,"_oembed_d01e104b758ab65a49dfdede5913069c":2,"_oembed_874fe46ae491204826d1694d2ef33bc0":2,"_oembed_8391feecdd4849ee3e1e157e0c2149eb":2,"_oembed_time_8391feecdd4849ee3e1e157e0c2149eb":2,"_oembed_time_874fe46ae491204826d1694d2ef33bc0":2,"_oembed_8954002f3cee8b890d4d590be308ea1a":2,"_oembed_time_8954002f3cee8b890d4d590be308ea1a":2,"_oembed_b0ae412e6c1109b456d564d524e039f4":2,"_oembed_time_b0ae412e6c1109b456d564d524e039f4":2,"_oembed_6fa7bb5895e39bde447f2aa42112350c":2,"_oembed_time_6fa7bb5895e39bde447f2aa42112350c":2,"_oembed_f284bc472428c21b3a384f58eeabdfe9":2,"_oembed_time_f284bc472428c21b3a384f58eeabdfe9":2,"_oembed_8c87a830bb75021cd30329a001513994":2,"_oembed_time_8c87a830bb75021cd30329a001513994":2,"_oembed_574f2ec202809f638414562e06899fc7":2,"_oembed_time_574f2ec202809f638414562e06899fc7":2,"_oembed_26afb00b3c55411ff47bd585cbb4a4eb":2,"_oembed_time_26afb00b3c55411ff47bd585cbb4a4eb":2,"_oembed_915f84bafbd1c86d8d5092d985805e15":2,"_oembed_time_915f84bafbd1c86d8d5092d985805e15":2,"_oembed_e77958e689d5721871a80e7c8a612eb8":2,"_oembed_time_e77958e689d5721871a80e7c8a612eb8":2,"_oembed_c8b968b747e20feab3d2d1f294ee3255":2,"_oembed_time_c8b968b747e20feab3d2d1f294ee3255":2,"_oembed_a850127c2f1bc6f60fea2e05360a4f09":2,"_oembed_565e1124b7db15585d4cffe6eddf1897":2,"_oembed_2c76f2bd52b1e4ddfc49d88c1cd75e57":2,"_oembed_time_2c76f2bd52b1e4ddfc49d88c1cd75e57":2,"_wpb_vc_js_status":2},"custom_fields_readonly_config":["title","description","keywords","_edit_last","_edit_lock","_wp_page_template","_wp_attachment_metadata","original_post_id","_wpml_original_post_id","_wp_old_slug","_icl_translator_note","_alp_processed","_pingme","_encloseme","_icl_lang_duplicate_of","_thumbnail_id","_wp_attached_file","_wp_attachment_image_alt","footnotes","_yoast_wpseo_title","_yoast_wpseo_bctitle","_yoast_wpseo_metadesc","_yoast_wpseo_metakeywords","_yoast_wpseo_focuskw","_yoast_wpseo_focuskeywords","_yoast_wpseo_meta-robots-noindex","_yoast_wpseo_meta-robots-nofollow","_yoast_wpseo_meta-robots-adv","_yoast_wpseo_canonical","_yoast_wpseo_redirect","_yoast_wpseo_opengraph-description","_yoast_wpseo_google-plus-description","_yoast_wpseo_twitter-title","_yoast_wpseo_twitter-description","_yoast_wpseo_opengraph-title","_yoast_wpseo_opengraph-image","_yoast_wpseo_twitter-image","_yoast_wpseo_primary_category","_yoast_wpseo_primary_product_cat","_form","_mail","_mail_2","_messages","_additional_settings","_locale","_elementor_page_settings","_elementor_edit_mode","_elementor_template_type","_elementor_version","_elementor_data","_elementor_css","_elementor_popup_display_settings","_yoast_wpseo_keyword","_cms_nav_minihome","_cms_nav_section","_top_nav_excluded","_attachment_original_parent_id","_menu_item_type","_menu_item_menu_item_parent","_menu_item_object_id","_menu_item_object","_menu_item_target","_menu_item_classes","_menu_item_xfn","_menu_item_url","_oembed_4321638fc1a6fee26443f7fe8a70a871","_oembed_29351fff85c1be1d1e9a965a0332a861","_oembed_9fcc86d7d9398ff736577f922307f64d","_oembed_366237792d32461d0052efb2edec37f5","_oembed_37fdfe862c13c46a93be2921279bf675","enclosure","_oembed_time_d01e104b758ab65a49dfdede5913069c","_oembed_ac49b172e1844531a885a53eff2efd91","_oembed_time_ac49b172e1844531a885a53eff2efd91","_oembed_d01e104b758ab65a49dfdede5913069c","_oembed_874fe46ae491204826d1694d2ef33bc0","_oembed_8391feecdd4849ee3e1e157e0c2149eb","_oembed_time_8391feecdd4849ee3e1e157e0c2149eb","_oembed_time_874fe46ae491204826d1694d2ef33bc0","_oembed_8954002f3cee8b890d4d590be308ea1a","_oembed_time_8954002f3cee8b890d4d590be308ea1a","_oembed_b0ae412e6c1109b456d564d524e039f4","_oembed_time_b0ae412e6c1109b456d564d524e039f4","_oembed_6fa7bb5895e39bde447f2aa42112350c","_oembed_time_6fa7bb5895e39bde447f2aa42112350c","_oembed_f284bc472428c21b3a384f58eeabdfe9","_oembed_time_f284bc472428c21b3a384f58eeabdfe9","_oembed_8c87a830bb75021cd30329a001513994","_oembed_time_8c87a830bb75021cd30329a001513994","_oembed_574f2ec202809f638414562e06899fc7","_oembed_time_574f2ec202809f638414562e06899fc7","_oembed_26afb00b3c55411ff47bd585cbb4a4eb","_oembed_time_26afb00b3c55411ff47bd585cbb4a4eb","_oembed_915f84bafbd1c86d8d5092d985805e15","_oembed_time_915f84bafbd1c86d8d5092d985805e15","_oembed_e77958e689d5721871a80e7c8a612eb8","_oembed_time_e77958e689d5721871a80e7c8a612eb8","_oembed_c8b968b747e20feab3d2d1f294ee3255","_oembed_time_c8b968b747e20feab3d2d1f294ee3255","_oembed_a850127c2f1bc6f60fea2e05360a4f09","_oembed_565e1124b7db15585d4cffe6eddf1897","_oembed_2c76f2bd52b1e4ddfc49d88c1cd75e57","_oembed_time_2c76f2bd52b1e4ddfc49d88c1cd75e57","_wpb_vc_js_status"],"custom_fields_translation_custom":[],"custom_fields_translation_custom_readonly":[],"doc_translation_method":"ATE","__custom_types_readonly_config_prev":[],"custom_types_readonly_config":[],"__custom_fields_readonly_config_prev":["title","description","keywords","_edit_last","_edit_lock","_wp_page_template","_wp_attachment_metadata","original_post_id","_wpml_original_post_id","_wp_old_slug","_icl_translator_note","_alp_processed","_pingme","_encloseme","_icl_lang_duplicate_of","_thumbnail_id","_wp_attached_file","_wp_attachment_image_alt","footnotes","_yoast_wpseo_title","_yoast_wpseo_bctitle","_yoast_wpseo_metadesc","_yoast_wpseo_metakeywords","_yoast_wpseo_focuskw","_yoast_wpseo_focuskeywords","_yoast_wpseo_meta-robots-noindex","_yoast_wpseo_meta-robots-nofollow","_yoast_wpseo_meta-robots-adv","_yoast_wpseo_canonical","_yoast_wpseo_redirect","_yoast_wpseo_opengraph-description","_yoast_wpseo_google-plus-description","_yoast_wpseo_twitter-title","_yoast_wpseo_twitter-description","_yoast_wpseo_opengraph-title","_yoast_wpseo_opengraph-image","_yoast_wpseo_twitter-image","_yoast_wpseo_primary_category","_yoast_wpseo_primary_product_cat","_form","_mail","_mail_2","_messages","_additional_settings","_locale","_elementor_page_settings","_elementor_edit_mode","_elementor_template_type","_elementor_version","_elementor_data","_elementor_css","_elementor_popup_display_settings","_yoast_wpseo_keyword","_cms_nav_minihome","_cms_nav_section","_top_nav_excluded","_attachment_original_parent_id","_menu_item_type","_menu_item_menu_item_parent","_menu_item_object_id","_menu_item_object","_menu_item_target","_menu_item_classes","_menu_item_xfn","_menu_item_url","_oembed_4321638fc1a6fee26443f7fe8a70a871","_oembed_29351fff85c1be1d1e9a965a0332a861","_oembed_9fcc86d7d9398ff736577f922307f64d","_oembed_366237792d32461d0052efb2edec37f5","_oembed_37fdfe862c13c46a93be2921279bf675","enclosure","_oembed_time_d01e104b758ab65a49dfdede5913069c","_oembed_ac49b172e1844531a885a53eff2efd91","_oembed_time_ac49b172e1844531a885a53eff2efd91","_oembed_d01e104b758ab65a49dfdede5913069c","_oembed_874fe46ae491204826d1694d2ef33bc0","_oembed_8391feecdd4849ee3e1e157e0c2149eb","_oembed_time_8391feecdd4849ee3e1e157e0c2149eb","_oembed_time_874fe46ae491204826d1694d2ef33bc0","_oembed_8954002f3cee8b890d4d590be308ea1a","_oembed_time_8954002f3cee8b890d4d590be308ea1a","_oembed_b0ae412e6c1109b456d564d524e039f4","_oembed_time_b0ae412e6c1109b456d564d524e039f4","_oembed_6fa7bb5895e39bde447f2aa42112350c","_oembed_time_6fa7bb5895e39bde447f2aa42112350c","_oembed_f284bc472428c21b3a384f58eeabdfe9","_oembed_time_f284bc472428c21b3a384f58eeabdfe9","_oembed_8c87a830bb75021cd30329a001513994","_oembed_time_8c87a830bb75021cd30329a001513994","_oembed_574f2ec202809f638414562e06899fc7","_oembed_time_574f2ec202809f638414562e06899fc7","_oembed_26afb00b3c55411ff47bd585cbb4a4eb","_oembed_time_26afb00b3c55411ff47bd585cbb4a4eb","_oembed_915f84bafbd1c86d8d5092d985805e15","_oembed_time_915f84bafbd1c86d8d5092d985805e15","_oembed_e77958e689d5721871a80e7c8a612eb8","_oembed_time_e77958e689d5721871a80e7c8a612eb8","_oembed_c8b968b747e20feab3d2d1f294ee3255","_oembed_time_c8b968b747e20feab3d2d1f294ee3255","_oembed_a850127c2f1bc6f60fea2e05360a4f09","_oembed_565e1124b7db15585d4cffe6eddf1897","_oembed_2c76f2bd52b1e4ddfc49d88c1cd75e57","_oembed_time_2c76f2bd52b1e4ddfc49d88c1cd75e57","_wpb_vc_js_status"],"__custom_term_fields_readonly_config_prev":[],"custom_term_fields_readonly_config":[],"custom_fields_encoding":{"footnotes":"json","_yoast_wpseo_keyword":"json","_yoast_wpseo_focuskeywords":"json"},"custom_fields_editor_label":{"_yoast_wpseo_bctitle":"Breadcrumb Title","_yoast_wpseo_metadesc":"Meta Description","_yoast_wpseo_metakeywords":"Meta Keywords","_yoast_wpseo_focuskw":"Focus Keyword","_yoast_wpseo_focuskeywords":"Focus Keywords"},"custom_fields_attributes_whitelist":{"footnotes":{"*":{"content":"Footnote"}},"_yoast_wpseo_focuskeywords":{"*":{"keyword":""}},"_mail":{"subject":"","body":""},"_mail_2":{"subject":"","body":""}},"taxonomies_readonly_config":{"translation_priority":1,"wp_theme":0,"team-category":1,"portfolio-category":1,"testimonial-category":1,"cookielawinfo-category":1,"elementor_library_type":0},"custom-types_readonly_config":{"attachment":1,"wp_block":1,"wp_navigation":1,"wp_template":1,"wp_template_part":1,"wpcf7_contact_form":1,"teams":1,"portfolios":1,"testimonials":1,"rselements_pro":1,"acf-post-type":0,"acf-taxonomy":0,"acf-ui-options-page":0,"cookielawinfo":1,"elementor_library":1,"e-landing-page":2,"e-floating-buttons":2},"notification":{"new-job":1,"include_xliff":0,"completed_frequency":3,"completed":1,"resigned":1,"overdue":1,"overdue_offset":7,"dashboard":true,"purge-old":7}},"custom-types_sync_option":{"attachment":1,"wp_block":1,"wp_navigation":1,"wp_template":1,"wp_template_part":1,"acf-post-type":0,"acf-taxonomy":0,"acf-ui-options-page":0,"wpcf7_contact_form":1,"cookielawinfo":1,"elementor_library":1,"e-landing-page":2,"e-floating-buttons":2,"mc4wp-form":1,"teams":1,"portfolios":1,"testimonials":1,"rselements_pro":1},"language_selector_initialized":1,"site_does_not_use_icl":true,"xliff_newlines":2,"tm_xliff_version":"12","gettext_theme_domain_name":"default,reobiz,acf,custom-post-type-ui,rsaddon,breadcrumb-navxt,one-click-demo-import,Widgets,WPML,litespeed-cache,redux-framework,wpml-cms-nav,sitepress,wordpress-seo,wordpress-seo-premium,wpml-translation-management,cookie-law-info,wordfence,admin_texts_cptui_post_types,admin_texts_cptui_taxonomies,admin_texts_reobiz_option,admin_texts_wpseo_titles,elementor,duplicate-page,envato-market,mailchimp-for-wp,google-site-kit,revslider,ultimate-coming-soon,wpml-string-translation,contact-form-7-multilingual,rs_framework,wage-conversion-calculator,sitepress-multilingual-cms,wp-seo-multilingual,cmb2,Main Menu menu,Main Menu (eng) menu,installer,rsframework,medvill,prelements,plugin-domain,tgmpa,gtranslate,contact-form-7,wpml,tinymce-advanced,classic-editor,WordPress,updraftplus","theme_localization_load_textdomain":2,"last_picked_up":1742840881,"hidden_languages":[]},"installer":{"version":"3.1.11","repositories":{"wpml":{"api-url":"https:\/\/api.wpml.org\/","bucket-url":"not assigned","subscription":{"key":"MDrZiTBiHy","key_type":1,"data":{"subscription_type":6719,"expires":"2026-03-24","status":"1","notes":"","order_id":"16853391","hasAutoRenewal":true},"registered_by":1,"site_url":"https:\/\/www.solutiiresurseumane.ro"},"last-successful-subscription-fetch":"2025-03-28 05:32:10"},"toolset":{"api-url":"https:\/\/api.toolset.com\/","bucket-url":"not assigned","subscription":"","last-successful-subscription-fetch":"none"}},"instances":{"\/home\/neurofee\/solutiiresurseumane.ro\/wp-content\/plugins\/sitepress-multilingual-cms\/vendor\/otgs\/installer\/installer.php":{"bootfile":"\/home\/neurofee\/solutiiresurseumane.ro\/wp-content\/plugins\/sitepress-multilingual-cms\/vendor\/otgs\/installer\/installer.php","version":"3.1.11","args":{"plugins_install_tab":1,"site_key_nags":[{"repository_id":"wpml","product_name":"WPML","condition_cb":[{"locale_utils":{},"footer_preview":false,"icl_translations_cache":null,"icl_language_name_cache":{},"icl_term_taxonomy_cache":null,"ROOT_URL_PAGE_ID":null,"wpdb":{"show_errors":false,"suppress_errors":false,"last_error":"","num_queries":184,"num_rows":0,"rows_affected":0,"insert_id":0,"last_query":"SELECT option_value FROM wp4v_options WHERE option_name = \u0027updraftplus_migrated_site_domain\u0027 LIMIT 1","last_result":[],"queries":null,"prefix":"wp4v_","base_prefix":"wp4v_","ready":true,"blogid":0,"siteid":0,"tables":["posts","comments","links","options","postmeta","terms","term_taxonomy","term_relationships","termmeta","commentmeta"],"old_tables":["categories","post2cat","link2cat"],"global_tables":["users","usermeta"],"ms_global_tables":["blogs","blogmeta","signups","site","sitemeta","registration_log"],"old_ms_global_tables":["sitecategories"],"comments":"wp4v_comments","commentmeta":"wp4v_commentmeta","links":"wp4v_links","options":"wp4v_options","postmeta":"wp4v_postmeta","posts":"wp4v_posts","terms":"wp4v_terms","term_relationships":"wp4v_term_relationships","term_taxonomy":"wp4v_term_taxonomy","termmeta":"wp4v_termmeta","usermeta":"wp4v_usermeta","users":"wp4v_users","blogs":null,"blogmeta":null,"registration_log":null,"signups":null,"site":null,"sitecategories":null,"sitemeta":null,"field_types":{"post_author":"%d","post_parent":"%d","menu_order":"%d","term_id":"%d","term_group":"%d","term_taxonomy_id":"%d","parent":"%d","count":"%d","object_id":"%d","term_order":"%d","ID":"%d","comment_ID":"%d","comment_post_ID":"%d","comment_parent":"%d","user_id":"%d","link_id":"%d","link_owner":"%d","link_rating":"%d","option_id":"%d","blog_id":"%d","meta_id":"%d","post_id":"%d","user_status":"%d","umeta_id":"%d","comment_karma":"%d","comment_count":"%d","active":"%d","cat_id":"%d","deleted":"%d","lang_id":"%d","mature":"%d","public":"%d","site_id":"%d","spam":"%d"},"charset":"utf8mb4","collate":"utf8mb4_unicode_520_ci","func_call":"$db-\u003Equery(\u0022SELECT option_value FROM wp4v_options WHERE option_name = \u0027updraftplus_migrated_site_domain\u0027 LIMIT 1\u0022)","is_mysql":true,"time_start":null,"error":null,"categories":"wp4v_categories","post2cat":"wp4v_post2cat","link2cat":"wp4v_link2cat"}},"setup"]}]},"delegated":true}}}}}
March 29, 2025 at 8:46 am #16875018
andreeaN-3
I've tried every option I know. 🙂 I don't know what else to do.
March 30, 2025 at 2:38 pm #16876671
andreeaN-3
I resolve this, thanks!
