Last updated by Long Nguyen 1 year, 6 months ago.
Assisted by: Long Nguyen.
June 9, 2023 at 7:37 am #13797329
olegA-5
I also have the following part (classic editor):
<table id="myTable">
<thead>
<tr>
<th>Страна</th>
<th>Подписание</th>
</tr>
</thead>
<tbody>
<tr>
<td>Албания</td>
<td>13.07.1995</td>
</tr>
</tbody>
</table>
In the ATE I don't see "13.07.1995" as requiring translation because it's treated as numbers with some punctuation not to be translated. What rule should I add to wpml-config to have "13.07.1995", i.e. _all_ numbers within table with id="myTable", to be registered for mandatory translation?
Thank you!
June 9, 2023 at 7:52 am #13797433
Long Nguyen
Hi Oleg,
To translate the numeric value in ATE, please add the following code to the file functions.php in your theme/child theme folder
 * Allow translating numbers
 * @see https://wpml.org/forums/topic/wpbakery-post-grid-element-exclude-from-filter-list-category-reappears
function wpmlsupp_7499_allow_translating_numbers( $is_translatable, $job_translate ) {
    $data = $job_translate['field_data'];
	if ( 'base64' === $job_translate['field_format'] ) {
		$data = base64_decode( $data );
    if ( is_numeric( $data ) ) {
    	return true;
    return $is_translatable;
add_filter( 'wpml_tm_job_field_is_translatable', 'wpmlsupp_7499_allow_translating_numbers', 10, 2 );
Then update the page > Update the translation and search for the number in ATE to translate it, please check this screenshot hidden link
Look forward to your reply.
June 9, 2023 at 8:42 am #13797905
olegA-5
Hello again,
It doesn't work for me, at least, by itself.
Again, I'm not looking for a way to _manually search_ (and than translate) the numbers, I need all of them be registered for _mandatory_ translation.
BTW, as I clearly see, it's about base64 encoding, which the WPBakery from the original support ticket uses. But I believe that I don't use this encoding. Moreover, this code definitely requires or specifics, or some additional config rules, or both, since I need only numbers within myTable to be registered for mandatory translation, not all numbers everywhere.
Thank you!
June 12, 2023 at 7:27 am #13806667
Long Nguyen
As I replied in the other ticket https://wpml.org/forums/topic/wpml-config-rule-for-href-within-content-of-a-shortcodes-tag-and-for-numbers/#post-13806661
you need to search for the number and translate it in ATE.
June 15, 2023 at 11:32 am #13831695
olegA-5
Too bad, but thank you for your assistance!
June 16, 2023 at 1:14 am #13835853
Long Nguyen
Feel free to open new tickets if you have any questions. Thanks and have a good day 🙂
