The client is experiencing an issue where navigating to
www.domain.com
redirects to the homepage of the main language instead of redirecting to the correct language version of the site.
We recommend informing the hosting support about the issue with WPML when using NGINX and a different domain per language and asking to review the DNS settings of the server.
Please note that the solution provided might be irrelevant if it's outdated or not applicable to your case. If after checking the known issues and confirming that you have the latest versions of themes and plugins the problem persists, we highly recommend opening a new support ticket. You can do so by visiting the WPML support forum.
Last updated by Andreas W. 1 year, 11 months ago.
March 23, 2024 at 4:33 pm #15443355
haraldK-9
one more:
i have also a problem with the www. part.
domain.com does redirect correct to the cirrect language
hidden link does redirect to the homepage of the "main language"
i checked dns settings twice and i asked their support they said all is good.
any advice what here is wrong?
Thank you again for your help!
March 23, 2024 at 4:36 pm #15443366
haraldK-9
Can i send you the Credentials somehow? So you can check the website?
Thank you in advance
March 23, 2024 at 6:55 pm #15443426
It would also be very helpful if you could send me a screenshot of your DNS setup.
As far I am aware, each domain must be registered with and without "www" and the second language domains need to point to the main site domain by using an ARecord entry.
Is this the case?
It would also be very helpful if you could send us the WPML information for troubleshooting.
More information about this here:
https://wpml.org/de/faq/provide-debug-information-faster-support
I would like to offer to have a closer look at the problem and request temporary access (wp-admin) to the website to investigate this issue further.
IMPORTANT
Video:
March 24, 2024 at 12:51 am #15443582
Could you please inform the hosting support about the following known issues and ask them to try out the suggested workaround?
https://wpml.org/errata/home-page-redirects-to-default-language-with-nginx-and-a-different-domain-per-language/
I will be awaiting your feedback.
March 24, 2024 at 12:48 pm #15443843
haraldK-9
The hosting provider was able to fix the nginx config.
Thank you
