Supporter timezone: Africa/Cairo (GMT+02:00)
This topic contains 23 replies, has 3 voices.
Last updated by Osama Mersal 1 year ago.
Assisted by: Osama Mersal.
December 11, 2023 at 9:15 am #15034287
Osama Mersal
I'll consult our compatibility team to check if there is another workaround for the case.
Thanks for your patience!
Osama
December 15, 2023 at 5:53 am #15069525
raviS-7
Can you please provide ETA on this?
December 15, 2023 at 1:45 pm #15073443
Osama Mersal
Our ATE and compatibility teams are checking the issue, but it's tricky because it sometimes happens, and other times it doesn't with slightly different texts.
Checking the issue might take some time due to the holidays.
Osama
December 28, 2023 at 2:52 pm #15135224
Osama Mersal
Thanks for your patience. Could you please check if the sandbox site works correctly? (hidden link)
If yes, please add the following line to your site's function.php file and check the issue.
remove_filter( 'the_content', 'wpautop' );
Osama
January 5, 2024 at 8:00 am #15153319
raviS-7
Hi, adding remove_filter as mentioned above causing other issues like not creating paragraphs. Please suggest some other solution.
January 6, 2024 at 11:38 am #15156652
Osama Mersal
Unfortunately, there isn't another workaround at the moment. Our ATE team is checking the issue further to get a solution.
Thanks for your understanding, and sorry for the inconvenience
Osama
January 9, 2024 at 1:50 pm #15164886
Osama Mersal
Could you please share your Debug information with us? Our ATE team wants to check some things.
Osama
January 12, 2024 at 5:52 am #15177227
raviS-7
Please fix this issue ASAP.
January 12, 2024 at 12:19 pm #15178905
Osama Mersal
Thanks for the debug info. Please edit the problematic page/post in the default language, make a minor edit, and update it.
After that, please go to WPML-> Translation Management, select the page/post, and send it to automatic translation.
Kindly let me know if the automatic translation result is correct now.
Please note that the fix is applied to the site in the debug info.
Osama
The topic ‘[Closed] strange issue with auto translations’ is closed to new replies.
