Strings inside the cart page can not be translated
The customer used an element from Elements pro plugin which is not compatible with WPML, that is why the strings from the Elementor elements of that plugin was not available in translation editor.
The solution was to use the manual translation mode for the cart page.
Relevant Documentation:
Last updated by Christopher Amirian 1 year, 6 months ago.
January 30, 2024 at 2:19 pm
urosJ-2
Problem 1. some strings are locked. it says: This setting is locked by a WPML configuration file.
Problem 2. Some strings are in still in my native language "slovenian" and i want to translate them. one thing is on cart: "cena", "izdelek" -> "price", "product". When i find the string it says that "cena" (price) is english original and that i have to translate. But thats nbot correct. Under english flag it should say "price"
January 30, 2024 at 3:13 pm
January 30, 2024 at 3:14 pm #15244882
Christopher Amirian
WPML Supporter since 07/2020
Please get back to us with the login information of the website copy by setting the next reply as private.
We will check to see why the strings at the top of the cart page table is not showing as translated when you already translated them in string translation.
January 30, 2024 at 3:26 pm
January 30, 2024 at 3:27 pm #15245116
urosJ-2
Did you get the new stage access?
Edit: i also granted access to the themes author (xstore)
January 31, 2024 at 10:01 am #15248359
Christopher Amirian
Would you please check this video?
What I have done:
- Go to WordPress Dashboard > WPML > Translation Management
- From the top filter, select Pages.
- Select the cart page and at the bottom of the screen select the Translation Myself button and send to translation button.
- Go to WPML > Translation menu and click the translate button next to the cart page in the list.
- Yu will see all the text you head issues with there in the translation editor, make sure you translate all and have the translation 100% complete.
Here is the result in the staging website: (I only translated PRICE and copied the other ones as a test):
January 31, 2024 at 10:36 am #15248478
urosJ-2
Thank you for the reply. I checked and the "price" (cart) on stage is not translated to english.
Also i did do as you told me (translate myself) and the cart didn't move to "translate" for me to translate it? All i see are 4 entries that already have been completed.
Picture after adding cart to translate que (it's not there): hidden link
Video: hidden link
January 31, 2024 at 10:55 am #15248561
urosJ-2
And what about the strings that are locked?
January 31, 2024 at 2:03 pm #15249669
urosJ-2
Any news?
January 31, 2024 at 3:33 pm #15250234
Christopher Amirian
Thank you for the video. I decided to record the troubleshooting live so you can see the thinking behind my actions and I found the issue:
Video 1:
Video 2:
And please check hidden link (I only translated Price)
Thanks 🙂
February 2, 2024 at 11:51 am #15258967
urosJ-2
Thank you for your work. All problems have been solved.
