Last updated by Lauren 3 weeks ago.
Assisted by: Lauren.
March 10, 2025 at 5:27 pm #16797817 | |
growingoldU |
March 10, 2025 at 7:31 pm #16798259 | |
Lauren Supporter
Languages: English (English ) Timezone: America/New_York (GMT-04:00) |
I would like to request temporary access (wp-admin and FTP) to your site to take better look at the issue. You will find the needed fields for this below the comment area when you log in to leave your next reply. The information you will enter is private which means only you and I can see and have access to it. Our Debugging Procedures I will be checking various settings in the backend to see if the issue can be resolved. Although I won't be making changes that affect the live site, it is still good practice to backup the site before providing us access. In the event that we do need to debug the site further, I will duplicate the site and work in a separate, local development environment to avoid affecting the live site. Privacy and Security Policy We have strict policies regarding privacy and access to your information. Please see: **IMPORTANT** - Please make a backup of site files and database before providing us access. - If you do not see the wp-admin/FTP fields this means your post & website login details will be made PUBLIC. DO NOT post your website details unless you see the required wp-admin/FTP fields. If you do not, please ask me to enable the private box. The private box looks like this: hidden link |
March 11, 2025 at 6:21 pm #16803577 | |
Lauren Supporter
I logged in and took a look at your site. It looks like background color is not showing correctly for the default language. If you disable WPML temporarily, does the correct background color show for the default language? If not, you'll need to resolve it with WPML deactivated and then we should be able to copy the background color settings correctly. Please let me know the results of this test. |
March 17, 2025 at 11:50 am #16824280 | |
growingoldU |
Hello, I'm sorry for the delay answering. Yes, when I deactivate WPML the correct background color shows for the default language. |
March 18, 2025 at 2:18 am #16827593 | |
Lauren Supporter
I'm going to need to test your site in minimal settings, meaning only WPML plugins active with the Divi theme, to see if we can reproduce this. Do you have a staging site where we can test this? if no, you can use a plugins uch as WPStaging or something similar to create one. If that is not possible, let me know and I can set one up for you and migrate your site there. |
March 19, 2025 at 3:48 pm #16836273 | |
growingoldU |
Hello Lauren, I tried to create a staging website however I got an error message due to exceeding memory on my host. I have the website's backup (with the plugin Migration, Backup, Staging – WPvivid Backup & Migration) and the website is in maintenance mode right now too. Can you help me with the staging website, please? |
March 20, 2025 at 11:53 am #16839827 | |
Lauren Supporter
Please see my previous private reply and let me know once the migration is complete. |
March 20, 2025 at 12:12 pm #16839868 | |
growingoldU |
The migration is complete. |
March 21, 2025 at 11:47 am #16844235 | |
growingoldU |
Hello Lauren, How are things going with the footer? I have urgency to solve this, since is the last task to fully complete the website. |
March 21, 2025 at 9:55 pm #16846519 | |
Lauren Supporter
I've got it working in Portugues, but still not in French. I noticed that the WP Memory is set at 40 which is below the required limit, and this can cause all sorts of problems. Please increase the memory, then update the French translation of the footer layout and let's see if that resolves the issue. If you want me to do this for you, just let me know here that I have permission to install the WP File Management plugin and I can test increasing the memory. |
