Last updated by Bobby 1 year, 9 months ago.
Assisted by: Bobby.
September 20, 2023 at 7:40 pm #14433243
marcelI-3
Tell us what you are trying to do? I try to open -> Translation Management -> Tools
Is there any documentation that you are following? Yes: https://wpml.org/documentation/automatic-translation/how-to-change-automatic-translation-engines/
Is there a similar example that we can see? No, I see the attached error after trying multiple times to reach this page
What is the link to your site? hidden link
September 20, 2023 at 10:19 pm #14433693
Bobby
WPML Supporter since 04/2015
Did you recently migrate your website? Please go to WPML->Support->ATE error logs -> share with me the top 3 errors.
Also go to Plugins->Add new->Commercial tab -> Check for updates --> Is it working as expected and connected to WPML ?
September 21, 2023 at 7:27 am #14435013
marcelI-3
We never migrate, but we also having a staging site on a different server, as you can see in our account.
Attached is the ATE error log and also for your reference, all plugins up to date
Please help again.
September 21, 2023 at 5:18 pm #14441417
Bobby
Thank you for the screenshot!
- Go to WPML > Translation Management
- Click on "Translators"
- Check if your user is defined as a translator. If not, please configure it again.
September 21, 2023 at 10:01 pm #14442575
marcelI-3
Hello again, users are defined. The second one is me... logged in.
September 22, 2023 at 7:22 pm #14449113
Bobby
Thank you,
Bobby
September 25, 2023 at 7:42 pm #14461849
Bobby
I have reviewed the backend and can verify that this issue is most likely caused by a third party plugin.
In order to identify the plugin the steps are to deactivate the plugins either one by one until the issue is resolved then this will point out the culprit or in batches to speed the test up.
I can do this as long as I have your permission or you are welcome to test this on a staging server and let me know your results.
