If you're experiencing a 404 error when clicking on the WPML tab in your WordPress dashboard, it might be due to a missing file in the WPML plugin folder.
We recommend you follow these steps to resolve the issue:
1. Create a full site backup.
2. Navigate to Plugins -> Add new -> Commercial tab in your WordPress dashboard.
3. Check for updates and update the WPML plugins to the latest version.
4. Double-check if the issue has been resolved.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket.
Last updated by Carlos Rojas 1 month, 3 weeks ago.
Assisted by: Carlos Rojas.
May 9, 2025 at 7:47 am #17014954
robertK-110
I was trying to access the WPML tab in the WordPress dashboard. When I clicked on it, I was redirected to a 404 error page. The issue can be seen at the following link: hidden link
When I click on the WPML tab in the WordPress dashboard, it redirects me to a 404 error page.
Why does clicking on the WPML tab redirect me to a 404 error page?
How can I fix the 404 error when accessing the WPML tab?
May 9, 2025 at 9:40 am #17015645
Carlos Rojas
WPML Supporter since 03/2017
Thank you for contacting us
I suspect that the cause of the issue is a missing file in the WPML plugin folder. Please follow these steps:
- Create a full site backup
- Go to Plugins -> Add new -> Commercial tab
- Check for updated and update the WPML plugins to the latest version
- Double-check if the issue disappeared
Could you tell me the results of the steps described above?
Carlos
