You are trying to update content on your site using WPML, but the old translated content is not showing in the Advanced Translation Editor (ATE), although it appears on the frontend.
If you previously used the Classic Translation Editor (CTE) for adding or editing translations, this might be the cause. Content translated in CTE or imported will not be available in ATE if you switch the editor settings. To resolve this, you need to either continue using CTE or re-translate the content in ATE to utilize its translation memory features for future updates. Additionally, ensure that any translations you complete are 100% finished to be saved in the Translation Memory, allowing for subsequent updates.
Please note that translations done in CTE or the WordPress editor are stored in your site's database, and Translation Memory does not keep track of these translations.
If this solution does not apply to your case, or if it seems outdated, we recommend opening a new support ticket. We also advise checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, please visit our support forum.
Last updated by amiM-3 2 months, 2 weeks ago.
Assisted by: Waqas Bin Hasan.
November 28, 2024 at 10:05 am #16453908 | |
amiM-3 |
November 28, 2024 at 10:30 am #16454183 | |
Waqas Bin Hasan Supporter
Hi, Reference to our recent chat, please let me know when the staging site is ready. I've set your next reply as private to share this information safely. IMPORTANT: If you don't see the section for providing access information, do not write in the message box or the information may appear as public. See https://wpml.org/purchase/support-policy/privacy-and-security-when-providing-debug-information-for-support/ for details on privacy and security. Regards. |
November 29, 2024 at 6:16 am #16457715 | |
Thank you for the access, I've observed the issue and investigating in more detail. I'll get back to you accordingly. |
November 29, 2024 at 9:29 am #16458369 | |
Thank you for your patience and cooperation. I've escalated the matter to our 2nd tier team for further investigation, after creating an "All in one WP migration" site package (which is currently being downloaded - please do not remove it). I'll update you as soon as I've more information. |
December 3, 2024 at 12:38 pm #16471723 | |
Thank you for your patience and cooperation. Our team found that perhaps you previously used Classic Translation Editor for adding/editing the translations, is that correct? Because if I change WPML settings for existing content to use CTE, I can see translations in the CTE, although not fully completed (perhaps there have been changes later on). If that's the case, please note that content translated in different editor or imported will not be available in ATE (Advanced Translation Editor). So if now you change the Translation Editor setting for "Editor for translations previously created using Classic Translation Editor", to ATE, you'll have to translate the content again in ATE. That's when ATE 'll be able to keep track of the translation memory and later updates in the translation 'll be possible in the ATE. Please also note, that if you use CTE or WordPress editor, all the translations are stored in your own DB in your site. WPML has no track of such translations. Please let me know. |
December 9, 2024 at 6:05 am #16491016 | |
amiM-3 |
No, I clearly remember we used ATE, not classic but it isn't the same as it's now. I can see in ATE setting to use "Previous version" which was the editor that we used but when I use it still doesn't show the translations. Anyway, the current setting "Editor for translations previously created using Classic Translation Editor" didn't work, but if I use "Editor for new translations" to Classic Editor then I can see the translation texts in it. You can check with "Contact" page. And we had used Automatic Translation from "Translation Management". Is the solution now to use classic editor? |
December 9, 2024 at 11:56 am #16492549 | |
Thank you for the updates. No if you've used ATE previously for the translations, then using CTE for existing translations isn't the solution. I've escalated the issue again to our 2nd tier team for further investigation. I'll update you as soon as I've more information. |
December 12, 2024 at 4:23 am #16505940 | |
Thank you for your patience and cooperation. Our team investigated in much detail and found that the jobs created for your content previously are from an old time (early 2023). At that time it wasn't necessary to complete the translation to 100% and that's why no translation memory was saved. That's the reason you don't see when you try to edit/update the translation now for an existing content. So looks like, you'll have to translate the content once-again and complete it to 100% (so it is saved in Translation Memory). And then you'll be able to continue updating the translation whenever you want (as you've already noted). |
December 16, 2024 at 3:57 am #16515638 | |
amiM-3 |
Yes, that's from early 2023. But I remember we couldn't save the translation until it's 100% and we have completed to 100% even if it was same as English content to make 100%. |
December 16, 2024 at 7:58 am #16516098 | |
amiM-3 |
How does CTE works? I have added a text and completed translation from CTE but it doesn't show in translated content. I can see it in "Jobs" and it shows "In progress", how to make it complete? |
December 16, 2024 at 10:00 am #16516534 | |
Thank you for the updates. CTE works the same way as ATE but of course all translations are saved in your own site's database. You also need to make the translation 100% completed (a progress bar is shown at bottom of the editor) to consider it complete. Can you share the screenshot and page link where it is happening? So I can then take a look if needed. |
December 16, 2024 at 10:07 am #16516550 | |
amiM-3 |
Please check the "Contact" page in the staging site for the Italian language. |
December 17, 2024 at 9:56 am #16520679 | |
Thank you for your patience and cooperation. I checked Contact Us page for Italian which I could see was in progress but as soon as I clicked the save and close in the CTE, it was completed. I then added another line of text to the page, using default language and updated the Italian translation. I also updated French translation and it was completed in first try. I've recorded my screen to show the both cases: hidden link I'll recommend clearing the cache of your browser and check again. It'd be great if you can record your screen, so I can check the process for an understanding. |
December 18, 2024 at 6:51 am #16524255 | |
amiM-3 |
It's working now somehow. |
