Last updated by igorM-9 1 year, 10 months ago.
Assisted by: Osama Mersal.
January 8, 2023 at 1:48 pm #12771021 | |
igorM-9 |
What is the link to your site? Hello, I have a website with the default language Croatian. English product/translations are not showing for non logged in users, But when I click on any of them i gor page not found - 404 error, or Croatian page, or I believe it is the same problem as this: With best regards, |
January 9, 2023 at 7:04 am #12773223 | |
Osama Mersal Supporter
Languages: English (English ) Arabic (العربية ) Timezone: Africa/Cairo (GMT+02:00) |
Hi, Thanks for contacting WPML forums support. I'll be glad to help you today. Could you please try the following steps? 1- Go to Products-> All Products After publishing the translated products, please check them on the front end. Kindly let me know if the above steps helped you fix the issue. Best regards, |
January 9, 2023 at 7:53 am #12773437 | |
igorM-9 |
HI, I already checked that, also tried update original post (add small change), and then update translation, still the same... |
January 9, 2023 at 7:54 am #12773447 | |
Hi, Thanks for your update. I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP) Your next answer will be private, which means only you and I can access it. ❌ Please backup your database and website ❌ ✙ I would need your permission to de-activate and re-activate the Plugins and the Theme and change configurations on the site. This is also a reason the backup is critical. ✙ I also need your permission to take a local copy of your site to debug the issue without affecting your live site. Best regards, |
January 9, 2023 at 12:39 pm #12777167 | |
Hi, Thanks for the access details. I checked the issue and found that the product slug translation caused it, so I deleted it from WPML-> String Translation. After that, the product worked correctly in English. If you need to translate the slug, please go to WPML-> Settings-> Post Type Translation sections, and translate the slug. Best regards, |
January 9, 2023 at 2:52 pm #12778107 | |
igorM-9 |
Hi, thank you for help. What exactly that means, that I can't have product slug translated in English? When slug is not translated it works, but slug is then in main language, not in English. When I translate it (WPML-> Settings-> Post Type Translation), then again is not working. Can that problem somehow be solved, because that changes my url's/links, and I have to make redirect rules for all products. I'll do that if I have to, but I'll like to avoid that. Best regards |
January 9, 2023 at 3:27 pm #12778599 | |
Hi Igor, Thanks for your update. I found that the English slug translation works correctly when the "Indeed Ultimate Affiliate Pro" plugin is deactivated. Kindly deactivate it and check the English product. (hidden link) If it worked correctly, please check the plugin settings. It could be a configuration issue. Best regards, |
January 9, 2023 at 9:26 pm #12780069 | |
igorM-9 |
Hi, Simple updating plugin to latest version solved the problem! once again thank you for help Best regards, |
January 9, 2023 at 9:27 pm #12780071 | |
igorM-9 |
